Loose fitting tail piece into extension pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MikeA, Jul 3, 2008.
  1. MikeA
    MikeA New Member
    Nov 4, 2007
    I'm working on a Kitchen Sink with dishwasher attached.
    This is the set up: the strainer body connects to the tail piece with a metal ring & rubber washer/ring and tightened with thumb screws. Then the 1 1/2" tail pipe slides into a 2" PVC pipe which is connected to the trap. The connection from the extension pvc pipe to the pvc trap is mended together some how (something clear colored) and I prefer not to break it unless necessary. The top of the PVC that the tail piece slides is unthreaded.
    Here's the problem: The new tail piece is the same 1 1/2" as the old one, but when I went to put it back into the 2" pvc it had some play where as it didn't with the old one. (I think over time stuff filled that space in.) I'm hoping to just replace the tail piece to the existing plumbing.
    I read the following thread which gives similar advise: http://www.terrylove.com/forums/showthread.php?t=21665
    Should I use the same adivse everyone gave on this thread? Which Desanko fitting would I use? Male/Female? Copper or PVC? Do you have any other advise?
    Thanks for your help!
    Michael
Similar Threads: Loose fitting
Plumbing Forum, Professional & DIY Advice Loose obsolete fitting adapter, how to fit? May 1, 2015
Plumbing Forum, Professional & DIY Advice Are there any qualitative differences between penetrating oils to loosen fittings? Jun 16, 2014
Plumbing Forum, Professional & DIY Advice Washer Supply Fittings Loose Apr 17, 2013
Plumbing Forum, Professional & DIY Advice Should 1/2" copper street ell be loose fitting? Oct 25, 2012
Plumbing Forum, Professional & DIY Advice Faucet was loose and moved a bit...Are my compression fittings OK? Aug 24, 2012
