Loose faucet base problem
djryval
Georgia
I have a single handle delta faucet in my kitchen and when you push the spout from one side of the sink to the other, the base of the faucet has some sloppiness to it now. It's not the actual "base", that part is secured down well with two locknuts on the underside of the sink. It's the part when the diverter goes. Here's an online pic I found that looks identical to what I'm referring to:
It has some play in it when you move the spout from left to right (or vice versa). I can actually see tow supply lines under the sink rotating just a little bit when you move it, so somehow that part is loose but I don't where you tighten it up. Any suggestions?
