Paperprofit
What's the easiest way to fix a closet-flange bolt that turns? If I install the toilet and try to tighten the two nuts that secure it to the closet flange, I can't because the bolt turns when I turn the nuts.
The closet flange (and drain pipe) are black plastic (ABS?). Is there a repair kit I can buy to fix this problem that will make the bolts "lock" into place or do I need to replace the flange (I assume it's cemented to the drain pipe).
Also, the existing closet flange bolts are carriage bolts but I bought new ones that have a flat, oval-shaped head (very different from a carriage bolt). Why the difference? Are they interchangable?
Thanks in advance!
Thanks in advance!
