Loop of wire outside of boxes. Is this normal?
Discussion in 'Electrical Forum discussion & Blog' started by Mr_Magoo, Aug 13, 2008.
  1. Mr_Magoo
    Mr_Magoo New Member
    Mar 8, 2008
    The carpenter framing my house says his electrician leaves a loop of wire outside of the box. I assume it is in case the drywall installers damage the wire, so more could be pulled inside the box. This is the first I have heard of this and have not wired my house that way. I can't find anything in the code that talks about extra wire outside the box only the length of wire required inside the box. Is it normal to put in a loop of wire outside the box?
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Only if you work with idiots... :D just kidding, the only time I leave a little slack is at certain type of ceiling boxes, other than that, no slack required and IMO, is a waste of time and someones money...
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    The centrifigal force gives the electrons a little boost just before they hit the outlet.
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    :D my vacuum works so much better after I installed speed loops....
  6. brownizs
    brownizs In the Trades
    Feb 9, 2006
    Springfield, IL
    If it is during Rough-In, this is normal.
  7. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I dont think so, normal would be everyone doing it.
  8. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    I would only leave extra loops of wire inside the wall for low voltage stuff... doorbell buttons, the doorbell transformer, doorbell, and HVAC thermostat.
    Every try to replace a doorbell button and there is not enough wire? :mad:
  9. brownizs
    Feb 9, 2006
    Springfield, IL
    I leave extra for LV such as Networking, Telephone, or Door Bell. As for the Rough-in, I always leave extra to allow for if the box would need to be moved during the Rough In stage, or in case some slack is needed on the other end.
    As for leaving behind the wall, I have only seen that with Light Fixtures, and for boxes, but only when the loop is secured behind the wall for safety.
  10. hj
    loops
    The loops should be horizontal in case the electricity does not have enough potential energy to make a loop the loop.
  11. Alectrician
    Jun 15, 2007
    I tried this on my toilet suppy line and it seems to flush quicker. :cool:
Similar Threads: Loop wire
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
Electrical Forum discussion & Blog Need help fixing ground loop Dec 25, 2011
Electrical Forum discussion & Blog Lighted switch on switch loop? Jun 16, 2008
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Mar 19, 2017
Electrical Forum discussion & Blog Can I wire in an oven to this sub panel? Feb 21, 2017
