Looks like we should wire with "pipe" !
Discussion in 'Electrical Forum discussion & Blog' started by ballvalve, Jun 17, 2012.
  1. ballvalve
    Dec 28, 2009
    northfork, california
    The skin effect is quite interesting, And perhaps it means we get better voltage transfer with stranded wire.
    http://en.wikipedia.org/wiki/Skin_effect ........ Quite an interesting article about electricity.
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    I don't deal much with high voltages, at least anything above 460VAC, but I always was under the impression that the skin effect is mostly at very high Kilovolts on power transmission lines. Silly me. And at my age, all those formulas just give me a headache.
  4. hj
    That is why high voltage conductors ARE basically 'pipe'. You would not like to try to wire a house with copper tubing, and the benefit would be so minimal, that you might not even be able to measure it.
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The use of metal pipes and “skin effects” can cause the metal raceway to become energized.
    The biggest problem with skin effects comes from frequencies not the amount of voltages. The higher the frequency the farther out the conductor the current flows. This is the reason we are required to bond both ends of a metal raceway that contains the grounding electrode conductor. Although lightning is a DC event it comes at very high frequencies.
  6. BobL43
    Mar 25, 2011
    Long Island, NY
    Ahem; is that last sentence what we would call an oxymoron? Like a Little Giant?;) does that happen frequently? You mean it is ziggy DC?
  7. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    The easy way to think about it is the level of voltage from beginning to end of the event varies from low to very high repeatedly and at a very high rate of speed between peak to peak thus a high frequency.
  8. jadnashua
    Lightning is often on/off (think squarewave) so it can approximate a very high frequency, but it's all DC (with a very high speed switch rate!). It looks continuous, but it isn't.
Similar Threads: Looks should
Electrical Forum discussion & Blog Adjusting wall plates - Moving switches & receptacle outward so wall plate looks good Dec 29, 2009
Electrical Forum discussion & Blog What wire gauge should I use Dec 30, 2015
Electrical Forum discussion & Blog Shouldn't Light Fixtures Have Bare Grounding Wire Connected? Dec 11, 2012
Electrical Forum discussion & Blog This is why no one should ever get cocky when someone explains electrical Jul 5, 2012
Electrical Forum discussion & Blog Old house, 100A fusebox, should we replace w. breakers? Jan 12, 2012
