Personalt
- Messages
- 22
- Reaction score
- 0
- Points
- 1
Any idea what type of faucet this is? I thought it was a delta 600 or similar. My original problem was handle broken and trim scratched. I bought a delta 600 kit thinking I would use the handle and and the trim and save the internal parts from a later day
- The handle goes up/down/left right like a delta 600.
- There is some markings on the copper trim from 'Ace' as in ace hardware I assume. But no markings that I could find that could indicate original brand. I am assuming the previous owner replaced the trim with trim from ACE.
- stem that goes in to the handle is much thicker then delta 600 and takes a screw hole in the the center of the handle rather then a screw that applies pressure to side of 'arm'
- 'cap' is different thread then a delta. It looks to be the same size but it is not. When you attempt to screw it in the size is slightly different or has a slightly thread. Looks like it might fit if you didnt care if you cross threaded it
- I started to pull the valve and it separated in half, the back half was plastic. The back half had two holes and the springs with washers in them. Holes were horizontal in orientation. Kinda like what I have seen in other faucets as part of the brass valve.
