Looking for Lasco shower/tub parts
Discussion in 'Shower & Bathtub Forum & Blog' started by Kelley G, Oct 16, 2007.
  1. Kelley G
    Kelley G New Member
    Jun 22, 2007
    hi,
    I have an older model Lasco shower/tub enclosure. the ss grab bar needs to be replaced, along with one missing grommet. I've contacted Lasco and they were absolutly no help.
    so far, I have been able to find acrylic rod material (6' lengths) but the grommets have got me stumped. does anyone know where I can purchase either one of these items?
    OD of bar - 7/8" (.875)
    OD of grommet hole - 1 1/16" (1.125)
    bar length - 16 3/4"
    thank you,
    Kelley
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Lasco won't be making the grab bars themselves.
    They wouldn't tell you where you could get a replacement or the company who makes it for them?
    Maybe they don't want to deal with the end user, have you tried to contact one of their Wholesalers or Retailers?
  4. Lancaster
    Lancaster New Member
    Nov 7, 2005
    The way I read this,the "bar" part of the grab bar is broken and you just want to replace that part and keep the end pieces.
    I'm trying to figure what broke a 7/8 thick stainless steel bar.I cant see where replacing it with an acrylic rod could possibly be safe.
    Carrying that further,I've never seen the "bar" part sold separately.To properly install a grab bar one would need access to the back (stud side) of the unit.
    Just to check,sure this is not a slide bar for a hand-shower? Or a towel bar?
  5. Duckman
    Duckman New Member
    Jun 2, 2009
    I know this is an old thread, but did you ever find those grommets? I have the same issue and found one other person who in the last two weeks has the same problem on a different forum.
  6. JDDoe
    JDDoe New Member
    Aug 20, 2010
    Well I consider myself to be pretty savvy when it comes to searching the web for items, but this one took some time. Definitely a hard to find item.
    I too was in need of these little plastic grommets and had some major ceiling damage below the tub when one of these had broken away in the kids tub and I was unaware it had been removed.
    So for those of you searching and searching - here they are - http://www.uspartscenter.com/towelgrabbar.aspx
  7. Duckman
    Duckman New Member
    Jun 2, 2009
  8. Pinewood
    Pinewood New Member
    Sep 2, 2010
    USA
    My question is, once you have the grommets and acrylic bar, how do you secure it to the tub? My old bar has clips on each end and I was able to remove it by twisting it and popping the clips off, but there is no way to put the clips back on as there is no access to the tub wall with out demoing the exterior wall the tub sits against. Is there an adhesive that can be used like Lexel caulk for instance and just applying it to the grommets and sliding the bar into the grommets and then caulking aroung the bar and grommets? Bad design by Lasko, great if it doesn't tear up, is my opinion and even worse that they do not offer any fix for this. My brother had this problem on a house he was remodeling for a customer a few years back and contacted Lasko and they sent directly to the customer a replacement bar that the customer was able to install but this is no longer done as I have contacted Lasko and they offer no replacement.
  9. Goodjoan
    Goodjoan New Member
    May 30, 2011
    GA
    I realize this thread is really old, but it's what pops up at the top of my google search over and over! I have the same problem, older house, the little inset towel bar fell out of 2 baths and I needed to replace them. I still have one of the bars but need to replace the other. Fortunately, one of the tubs still had the original grommet still in place! It is Heyco snap bushing ID#SB 1093-14, part number 2164. I went to Heyco's website and asked for a sample part and hopefully, will receive the order in a few days. I'm hoping it fits and can be used to reseat the original bar. I'll be using the links above to order an acrylic replacement for my other bath. Thanks for keeping this info here for us to find!!
  10. Briman
    Briman New Member
    Jul 19, 2014
    Kelly I know this is old. I just found myself in the same boat. On the grommet is a part number mine was
  11. Briman
    Briman New Member
    Jul 19, 2014
    sorry didnt get to finish the number on mine was
    heyco sb-1.093-14 websites I found all seem to link back to this
    http://www.ebay.com/itm/like/291051826814?lpid=82
  12. guyinsb
    guyinsb New Member
    Jan 20, 2012
    retired
    Santa Barbara, CA
    The ebay seller does in fact have the correct part. However, the grommet has two "catches" along the sleeve which can make installation tricky. I own an apartment built in 1977 with 36 shower stalls, each with the small towel bar insert, each with degraded or incorrectly installed grommets. Oi vey! Previous owners have dealt with the problem with silicone caulk.
    I just bought 34 of these grommets (in white) from mouser for 19 cents each, plus $5 shipping. Hope they are what I actually want! Keywords: Heyco 2164
  13. Duckman
    Duckman New Member
    Jun 2, 2009
    Put the grommets in first, then slide the bar in one side far enough to pull it back into the other side.
    Also found at
    http://www.shop.afpimaging.net/BUSHING-SNAP-HEYCO-SB-1093-14-0000030517.htm
  14. guyinsb
    guyinsb New Member
    Jan 20, 2012
    retired
    Santa Barbara, CA
    Once the grommet has been inserted, small "tabs" in the sleeve are forced into the interior of the sleeve, making it impossible to insert the pipe through the grommet. I guess the hole in the wall of the shower needs to have "notches" filed to permit the insertion of the grommets without bending the tabs.
  15. Demitri27
    Demitri27 New Member
    Aug 7, 2016
    New Jersey
    I bought the grommets and now cannot get the towel car in because of the tabs on them. Did anyone figure out how to make this work?
Similar Threads: Looking Lasco
Shower & Bathtub Forum & Blog Looking for Moen Brand faucet parts (1950's) Oct 14, 2016
Shower & Bathtub Forum & Blog I am looking for a quality white P.. May 12, 2015
Shower & Bathtub Forum & Blog Looking for high flow shower/tub fixture Feb 6, 2015
Shower & Bathtub Forum & Blog Purple or regular drywall with Kerdi membrane or Ardex 8+9? Looking at the best option Dec 14, 2014
Shower & Bathtub Forum & Blog A nicer looking out side corner Aug 9, 2014
