Looking For Advice on Waste/Venting for Remodel.
Drew Morrison
New York
Hello,
I'm new to the forum and looking for advice on a 3rd floor bath remodel. I have plumbed some sinks and a laundry drain, but this the most complex project so far.
This is a second bathroom using the main cast iron 'stack' in our home. I have access to a crawl space overhead (a small one but navigable, it's a Mansard Roof).
The previous owner hired someone who did not ad venting for any of the fixtures. I am confused if they were being lazy, or if they considered the stack to be providing venting for the tub, sink and toilet.
My setup will have a double sink, shower pan and toilet. I am hoping to move the toilet on the other side of the room (it was previously next to the stack). This will land the drain at 6'6" away, using 3" I believe this falls within code as long as the pitch is correct.
Please see attached image for my venting idea, which would involve creating a new 2" vent through the roof.
I have read that it's best to transition to a 3" at the roof, to avoid freezing in winter.
Any advice or pointers would be much appreciated!
Thanks,
Drew
Drew Morrison
New York
Your first problem is the you CANNOT use the stack from the lower bath as a drain for your new one, since it is the vent for the lower bath.
Hi HJ,
Thanks for your response - are you able to point me in the right direction? I didn't think about the relation between the 2nd and 3rd floor bath sharing that stack. Had thought it was a 'wet vent' situation.
Trying to DIY the right way!
Drew
Wet venting is only for bathroom fixtures on the "same" floor.
The vent stack from below would have other vents tied in, and the velocity from above would be a problem below.
Leave the vent alone, and bring up a new waste line for the third floor bath that can tie in "below" the other bath.
An example of stacked bathrooms here.
Also on your drawing you showed a backwards wye for the lavs and shower. You can't reverse the direction of the flow.
1.5" trap arm max distance = 42"
2.0" trap arm max distance = 60"
3.0" trap arm max distance = 72"
Drew Morrison
New York
An example of stacked bathrooms here. Also on your drawing you showed a backwards wye for the lavs and shower. You can't reverse the direction of the flow.
Hi Terry,
Thank you for the info! I have to rethink the project, but I understand now. Will probably repost a revised drawing.
Drew
