Looking for a creative (and pet friendly) plumber
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ShoelessJoe, Sep 30, 2013.
  1. ShoelessJoe
    ShoelessJoe New Member
    Sep 30, 2013
    St. Louis, MO
    I'm looking for a creative plumber who can help me out with a little project.
    I currently have this...
    And I would like to turn it into this
    The main differences are I'd like to have the first picture sitting on my kitchen floor and I'd like the feed to come from line similar to that of an ice maker.
    Your solution would need to:
    A) Allow me to drill a hole into the water tank and insert the feed
    B) Have some type of quick-release/shut-off valve so I could unhook and clean as needed
    C) Automatically fill the tank when the water got low but not overfill due to pressure in the line
    I'm not crafty, so if you're recommending I build this myself I'll need specific part names. I have zero plumbing experience and would rather just pay someone a few bucks to solve this problem so if there's any of you out there who might be interested just let me know.
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Not only easier, but a whole lot less expensive. You won't hire a plumber for "a few bucks", and I'm pretty sure a decent pet store will have something ready to go.
  5. ShoelessJoe
    Sep 30, 2013
    St. Louis, MO
    Well I appreciate both of you guys taking the time to respond but I wouldn't be asking if I could have just purchased something off the shelf. I've done a significant amount of research prior to posting this so for any future posters who'd like to respond please do so with the intent of actually helping. As far as "a few bucks" go Gary, how about you leave the price to me and the person actually doing the work.
  6. hj
    You would have to drill a hole in the side of the bowl, then install a "waterer" float valve. Your problem is that the hole would probably have to be below the water level of the bowl and the valve does not usually seal "water tight". You would also need enough room inside the chamber for the float to rise high enough to give the proper water level. There would be many ways to make the 'quick connection' depending on your exact situation. The real question, however, is HOW does the water get high enough to come out of that "slot"? You are probably going to pay a plumber at least $200.00, plus parts, if you can find one willing to try to drill the hole without damaging or destroying the bowl.
  7. mrbeing123
    mrbeing123 New Member
    Dec 5, 2012
    Louisiana USA
    Depending on how simple your existing unit is, it probably depends on the vacuum created in the water bottle to not overfill (kind of like the 5 gallon tank top water coolers do). Is it the looks of the unit you have now that you like? Would the second one you show connected to the garden hose not work? you can easily get garden hose to NPT pipe adapters(http://www.mcmaster.com/#garden-hose-adapters/=orhe0m) and then a fitting that adapts NPT to compression fittings as you call ice maker line. Quick disconnect garden hose connectors are readily available too. http://www.mcmaster.com/#garden-hose-adapters/=orhgew
    That would be your simplest, cheapest and safest bet IMHO. You could screw the connecters together in minutes. A float valve on the other tank could work if you drill into the bottle, but even the smallest air leak around that fitting, the dish would overfill quick. And if say Fido knocks over the dish, you would have full water pressure open onto the floor and would send him swimming for higher ground. I think modifying your existing one would be quite risky. The adapters on the garden hose one would be much safer.
  8. LindaK
    LindaK New Member
    Sep 29, 2013
    BC, Canada
    Okay, this is thinking way outside the box, but have you checked out stuff in gardening websites? They should have automatic plant watering systems that could be adapted. (??) They sense when the probe is dry.
  9. mrbeing123
    Dec 5, 2012
    Louisiana USA
    Or better yet, just leave the lid off the back of the toilet. That way you don't have to do a darn thing
  10. Smooky
    Apr 4, 2011
    North Carolina
    You need a Float Valve and some connections.
    http://www.wag.com/fish/p/coralife-float-valve-121866?site=CA&utm_source=Google&utm_medium=cpc_W&utm_term=ESU-051&utm_campaign=GooglePLA&CAWELAID=1323890911&utm_content=pla&ca_sku=ESU-051&ca_gpa=pla&ca_kw={keyword}
    http://www.marinedepot.com/Kent_Mar...r_Systems-Kent_Marine-KM1675-FIRORAFV-vi.html
    http://www.f3images.com/IMD/UserManuals/KM1651.pdf
    http://www.marinedepot.com/JG_1_4_i...lter_Systems-John_Guest-RO5351-FIROJG-vi.html
    http://www.usplastic.com/catalog/item.aspx?sku=58599&gclid=CJrJhpuf9rkCFY6Z4AodiAYAIw
    http://www.homedepot.com/p/Watts-1-...on-Self-Tapping-Saddle-Valve-LF-A50/202254838
  11. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    Years ago I did something like this using an automatic watering unit from a farm supply house. The problem is float valves do not always work right and may stick on or leak. In a toilet they just run and the over flow goes down the drain. I would never use a unit like that agian with out a floor drain close. We ended up with water on the floor fairly often.
    Now we just use an auto water unit with a larger tank.
Similar Threads: Looking creative
Plumbing Forum, Professional & DIY Advice Looking for my faucet make and/or model Saturday at 7:04 PM
Plumbing Forum, Professional & DIY Advice Looking for a 90° 1/4" male to 1/4" female compression adapter Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Help Looking for parts for this faucet Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Looking for push button timer shower rough in Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Looking for 3-inch ABS no-hub adapters in Seattle area Jun 22, 2016
