Long run for hot water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Interlodge, Aug 22, 2009.
  1. Interlodge
    Interlodge New Member
    Oct 10, 2008
    Since moving into house, the Hot water to kitchen sink has always needed to run about 15 seconds to purge cooled water from line. House originally built in late 70s. Doing some planning for a bath remodel, I was in the crawl space and noticed, what I would think is an unnesessary long supply line. The line runs from the water heater about 17 feet directly under a wet wall with supplies serving two baths, Then in makes a 90 turn and travels 14 nore feet and makes another 90 (completing a U) and travels 12 feet back to the kitchen sink. The kitchen sink is about 10 feet diagonally from the water heater.
    The only think I can think of is they wanted the kitchen faucet at the end of the line maybe with the theory that it would have less effect on the showers earlier on the line? Anyone know if this was a common or rational method back then?
    If that was the reason with new valves for showers would it matter any more ?
    One of the showers now has a pressure balanced valve and the other will ve getting a thermostatic.
    Could use recirculation I'd guess but run still seems unnecessarily excessive.
    Was thinking I could easily use a manifold about 5 feet away from the heater and then would have a 12' line serving the baths and about 7 to the kitchen form the manifold.
    any familar with anything that sounded like this setup? Thoughts about my resolution....?
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    you have two choices.
    1) You can cut and cap the existing line after the two baths and reroute the line directly from the heater. (the lass expensive option)
    2) You can add a return line from your kitchen to your heater which will give you instant hot water at all your fixtures. They even make a retrofit pump where you don't need to run any more copper.
Similar Threads: Long water
Plumbing Forum, Professional & DIY Advice Hot Water Takes Long Time for 2nd Bath Jan 9, 2017
Plumbing Forum, Professional & DIY Advice 1/2" Water Line 1/2" Water Line Split 12" long Mar 6, 2014
Plumbing Forum, Professional & DIY Advice 45 yr old condo - long time for water to get hot Sep 19, 2013
Plumbing Forum, Professional & DIY Advice Takes too long for hot water upstairs. Jul 23, 2013
Plumbing Forum, Professional & DIY Advice Help with BAD water hammer from a long downhill run! Jun 13, 2013
