Long distance outdoor lighting
Discussion in 'Electrical Forum discussion & Blog' started by Savageriver, Oct 18, 2009.
  1. Savageriver
    Savageriver New Member
    Oct 18, 2009
    Maryland
    Good Morning,
    I am trying to run an outdoor lighting system from my main panel to the front gate of my property. The total one-way run to a 3-way switch at the gate will be 275 feet so I guess that the total circuit length will be 550 feet plus a few feet to the lights. The load will be approximately 660 watts (5.5 amps?) of outdoor spot lights and be connected to a 15-amp breaker at the main panel. Can I run from the main panel to the LB fitting with 12-2 NM-B and then run from the LB fitting with 10 gauge to a junction box approximately half way to the 3-way switch at the gate? I’d like to come from the junction box to the 3-way switch at the gate with 12 gauge as I have the appropriate lengths of the different gauges of wire already.
    Thanks in Advance!
    SR
  2. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    When you run wire long distances, you get "voltage drop". There are many free "calculators" for this on the internet. Search google.com for the words...
    voltage drop calculator
    Some are easier to use than others. (You would select 1 phase or single phase.)
  4. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    You can splice inside the lb, but it must have enough room to handle the connductors.
    It will be better to install a weather proof box and make the splices there.
    Do you not have enough wire to make a complete run without splicing in the middle?
  5. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    Trying using UF-B 103/ground cable.
  6. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    1. Use a jbox instaed of an LB
    2. I always suggest against using birect buried cable/wire. Conduit is cheap insurance from damage, Stuff happens.
    3. Your voltage drop on 275' of #12 is about 5% or 6 volts. I would use #10 for that distance.
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Incands will last longer at lower voltages.
  8. Ian Gills
    Jul 24, 2007
    USA
    A lot longer.
  9. hj
    wire
    IF you are going from the panel, to the first switch, to the second switch, and then to the lights, you will need THREE wires, and the distance will only be 275'. If you go from the panel to the "second" three way, and from there back to the first one, and also to the lights, then you need FOUR wires and the distance will be 550'. PLus, either one will also need a ground wire.
  10. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    I would hope that much light will only be on infrequently. It would be awfully wasteful/hard on the wallet to have it on dusk to dawn (several thousand kwh/year). If it's going to be on dusk to dawn then you might want to consider more efficient lighting solutions.
Similar Threads: Long distance
Electrical Forum discussion & Blog Cat5/Coax run short distance along side electric conduit Jul 18, 2016
Electrical Forum discussion & Blog Another long electrical run Nov 19, 2016
Electrical Forum discussion & Blog Can I use 3 five foot extension cords instead of one long one? Jul 21, 2016
Electrical Forum discussion & Blog To Sub-panel Or Not To Sub-panel.. (long Circuit Runs) May 6, 2016
Electrical Forum discussion & Blog Outlet no longer works inquiry Apr 21, 2016
