With the 301.1.1 Approvals... are you saying that the tub since it is a 'device used in a plumbing system' would have to be approved? Or do you mean that any fitting I used for the waste and overflow would have to be UPC approved.
As far as I know...
Unless the fixture is "listed" by an approved listing agency (pre-approved), you would have to get your local plumbing code enforcement agency to issue an approval for it...
In Phoenix that usually involves hiring an engineering firm here and giving them a couple of tubs for testing (and a few thousand dollars for testing as well)... Upon them issuing a report in favor of the tubs, the code department will give you an "approval" for the one-time use of the tub...
UPC 2006:
301.1.1 Approvals. All pipe, pipe fittings,
traps, fixtures, material, and devices used in a
plumbing system shall be listed or labeled
(third-party certified) by a listing agency
(accredited conformity assessment body) and
shall conform to approved applicable recognized
standards referenced in this code, and shall be
free from defects. Unless otherwise provided for
in this code, all materials, fixtures, or devices
used or entering into the construction of
plumbing systems, or parts thereof, shall be
submitted to the Authority Having Jurisdiction
for approval.
301.2 Alternate Materials and Methods of
Construction Equivalency. Nothing in this code is
intended to prevent the use of systems, methods, or
devices of equivalent or superior quality, strength,
fire resistance, effectiveness, durability, and safety
over those prescribed by this code. Technical
documentation shall be submitted to the Authority
Having Jurisdiction to demonstrate equivalency. The
Authority Having Jurisdiction shall approve the
system method or device when determined to be
equivalent or superior.
However, the exercise of this discretionary
approval by the Authority Having Jurisdiction shall
have no effect beyond the jurisdictional boundaries
of said Authority Having Jurisdiction. Any alternate
material or method of construction so approved shall
not be considered as conforming to the requirements
and/or intent of this code for any purpose other than
that granted by the Authority Having Jurisdiction
when the submitted data does not prove equivalency.
301.2.1 Testing. The Authority Having Jurisdiction
shall have the authority to require tests, as
proof of equivalency.
301.2.1.1 Tests shall be made in accordance
with approved standards, by an approved
testing agency at the expense of the applicant.
In the absence of such standards, the
Authority Having Jurisdiction shall have the
authority specify the test procedure.
301.2.1.2 The Authority Having Jurisdiction
shall have the authority to require tests to be
made or repeated if, at any time, there is
reason to believe that any material or device
no longer conforms to the requirements on
which its approval was based.
