Location of Sand Trap?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by varunner, Apr 22, 2011.
  1. varunner
    varunner New Member
    Dec 13, 2010
    Virginia
    I have a submerged pump(120' deep) which has been pumping black sand since it was new, 12 yrs. ago. The amount of sand present in drinking glasses, and sinks varies over time from just a trace to a lot. During this time the water heater, toilet tanks, and the pressure tank all have accumulated alot of sand. Additionally it seems the bladder in the pressure tank is broken. So I'm planning on installing a sand trap, replacing the pressure tank and cleaning out/or replacing fixtures, water heater, etc. My question is, will it be ok to install the sand trap upstream of my pressure tank? My well piping enters my house crawlspace and runs about 20' , then into my attached garage where the pressure tank is located. I want the end of the 20' run to connect to the sand trap first, then to the manifold on the pressure tank. The reason I want to do this is to prevent sand building up in the pressure tank. Link for sand trap is below. thanks
    http://www.apwinc.com/mini-sand-trap.html
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The problem with putting the trap before the pressure tank is that if the trap ever plugs up or becomes full, the pump will keep running until it burns out.
  4. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    I recently installed a Lakos 10-20 GPM sand trap between the pump and tank. The Lakos supposedly won't plug up like a traditional filter since it is a cyclone separator. If it does fill up then it simply sweeps the excess sand to the tank and doesn't restrict the flow from the pump. I really like the Lakos brand and I mounted the filter to the wall. The only thing I have heard is that if your water quality is not great then choose the stainless. I'll see if I can attach a few pics...
  5. varunner
    varunner New Member
    Dec 13, 2010
    Virginia
    Thanks for the replies. I agree a plugged sand trap is a show stopper. I believe the one I'm looking at uses the same method to remove sand as the Lakos model. Stainless is nice, but my pressure tank is fiberglass, so a fiberglass sand trap is ok with me. I think I'll talk to the manufacturer about the dangers of someone not flushing out the sand on a regular basis. The risk seems low to me.
  6. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Most of these type of sand traps need to be installed between the pump and tank. They require a certain flow rate to operate properly. Between the pump and tank, they always have enough flow rate to work. After the tank they only have as much flow as you are using at the time, which may not be enough to function properly.
  7. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The risk can be mitigated with a PRV.
  8. varunner
    varunner New Member
    Dec 13, 2010
    Virginia
    How would a PRV function in this situation ?
  9. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    My bad for using a TLA. A pressure relief valve would relieve excess pressure either to the drain or to atmosphere depending where you plumb it to. It would work pretty much the same as a TPR valve on a water heater less the temperature component.
  10. varunner
    varunner New Member
    Dec 13, 2010
    Virginia
    On my system, there is a PRV on the manifold attached to the pressure tank. I think what I'll do is add another one on the pump side of my sand trap, that should take care of an over pressure if the sand trap becomes clogged up.
  11. KULTULZ
    KULTULZ Jack of all trades, Master of none
    Nov 13, 2006
    ROCKVILLE, MD
    ...hmm... Sounds good to me (I am not a professional). Any further comments?
    Would a system such as attached protect the pump if the sand/sediment filter actually plugged? Not have to worry about a relief valve relieving pump pressure?
    - http://www.amtrol.com/media/documents/wellxtrol/MC10187_4_11GuardianCPflyerlow.pdf
  12. valveman
    Mar 15, 2006
    Lubbock, Texas
  13. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    I have had great luck using the Lakos in well separators.
Similar Threads: Location Sand
Pumps and Tanks Well Forum & Blog. Water is life. Location of Freeze proof sand Point Apr 17, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Location Aug 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Cavitation due to Check Valve Location? Feb 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Dilema with well location Feb 17, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank relocation? Mar 26, 2014
