Location of irrigation Tee and Manifold
Discussion in 'Irrigation / Sprinkler Forum' started by dgeist, Aug 27, 2010.
  1. dgeist
    dgeist New Member
    Apr 11, 2009
    Georgia
    Greetings, I'm a DIYer looking at replacing my aging cast-iron (post-meter) residential supply line. Currently, there's a PVC tee inline between the meter and start of the iron pipe feeding an adjacent irrigation manifold cluster.
    I'm planning on re-plumbing the house supply with 1" soft copper and would like to put in a copper Tee at the house side and re-locate the irrigation manifold up there (and then patch-in runners down to the the branches leaving the current location of the manifold.
    I think I'm okay with respect to flow/resistance, etc. I want the manifold up near the house for cosmetic, access, and future expansion purposes. Any major issues that you folks see with this plan?
    Thanks
    Dan
  2. Fireguy97
    Fireguy97 Irrigation Contractor
    Mar 21, 2010
    Irrigation Contractor / Certified Backflow Assembl
    Kamloops, in Beautiful British Col
    Other that not knowing the distance between the new manifold location and the existing manifold location, there shouldn't be any problems. Just remember that the manifold is always better as close to the zone as possible. Also make sure that you allow for and have your backflow assembly tested after you make this plumbing change.
    Mick
  4. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Soldering underground is not allowed in some area's, something you may want to check before soldering the T.
  5. dgeist
    dgeist New Member
    Apr 11, 2009
    Georgia
    - Checking with local codes, now.
    - The current manifold is right against the trunk for one zone, and half way across the yard from the other. The new location will simply flip-flop the relative distances. There will be about a 50 foot addition between the manifold and first PVC Tee in the farthest zone. (They're all large-throw slow moving rotary lawn heads, BTW). They have fairly large diameter PVC feeds and I've yet to see any issues with flow.
    If soldering isn't permitted underground, how does one connect from the brass nipple on the meter side to the copper? Compression fitting? Or is it simply that ADDITIONAL solder joints are not allowed?
    Thanks.
    Dan
  6. Jerome2877
    Aug 25, 2009
    They can be compression, braised or flared. Sharkbite's could also be used there as well.
  7. dgeist
    dgeist New Member
    Apr 11, 2009
    Georgia
    Brazing is (correct me if I'm off here) the same basic process as soldering but with a different filler material and at a higher heat? I don't think I'd want a sharkbite connector buried (seen too many leak from improper use) and I don't see how a compression would be better than a solder....but I guess I don't write the codes.
    Dan
  8. hj
    quoe; Soldering underground is not allowed in some area's
    That ONLY applies to joints inside a building under a concrete slab. The irrigation connection can be any where you want it to be and once you install the "proper" backflow preventer, (not the $9.95 Home Depot special), you can do anything you wish to with the piping.
  9. Jerome2877
    Aug 25, 2009
    Ok very possible he is in an area where soldering underground is allowed and thats why I stated some area's, but some area's like my entire country, you cannot.
    7.2.9.2
    4) Except as provided in Sentence (5), joints in copper tubes installed underground shall be made with either flared or compression fittings, or be brazed using a brazing alloy within the American Welding Society's AWS-BCuP range.
    5) Compression fittings shall not be used underground under a building.
    There's my code, how about showing yours HJ!
Similar Threads: Location irrigation
Irrigation / Sprinkler Forum Central control valve location, pros and cons? Mar 21, 2007
Irrigation / Sprinkler Forum Bury drip irrigation main connected to hose bib? Mar 4, 2017
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum Irrigation Winterizing help Oct 27, 2016
Irrigation / Sprinkler Forum Reviving Old Irrigation System Oct 9, 2016
