location of clean out plug
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by utah109, Sep 17, 2006.
  1. utah109
    utah109 New Member
    Sep 17, 2006
    oklahoma
    My house was built in 1975 so i'm sure that it has one but i can't find it anywhere. I pretty sure that its buried somewhere. How would i go about finding it. Thanks
  2. Cass
    Cass Plumber
    Nov 12, 2005
    2 questions, are you on a slab and how far from the street are you?
  4. hj
    Co
    No way to tell from here, and even if we were there, once the cleanout is covered with dirt they can be almost impossible to located without putting a camera into the pipe to find where the "branch' opening is. I have probed the ground every few inches looking for them and when the camera found it, there were probe holes on all four sides of it. In some areas up to about that time, the cleanout was merely a tee with a plug in the top of the pipe about 2' from the house, and you have to dig down to it.
  5. utah109
    utah109 New Member
    Sep 17, 2006
    oklahoma
    yes i am on a slab and its around 10 yards to the street.
  6. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Are you trying to locate the end of line cleanout, or the cleanout that ties the building drain into the building sewer? (The building drain is the drain in/under the house, the building sewer is from the house to the city lateral) The end of the line cleanout is usually close to where the furthest toilet/fixture is located. Some codes allow you to delete the cleanout at the drain sewer tie in if the house is located within a certain distance from the city lateral.
  7. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    It's common in our area not to have a cleanout. Most plumbers won't even attempt to find one if the homeowner can't point it out to them. They just march up to the roof and use the vent(s) for snaking purposes. When I wanted to relocate some fixtures, I called the plumber who did the house when it was built (1973). He swore there was a cleanout, and marked the spot where it was. I dug until I could hear someone speaking Chinese without finding a cleanout, so went ahead and carved up the slab as necessary. Found that sure enough, there wasn't a cleanout; there is one now.
  8. utah109
    utah109 New Member
    Sep 17, 2006
    oklahoma
    Well i finally found it after going to a neighbors house to see where his was. altogether i probed for about an hour and i was fixing to give up when i hit it. Thanks for the help fellows.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    Like hj said they can be a pain to find. Were you able to open it easy?
Similar Threads: location clean
Plumbing Forum, Professional & DIY Advice Need Advice for Maximum slope and clean out location Apr 19, 2016
Plumbing Forum, Professional & DIY Advice Cleanout locations? Jul 13, 2012
Plumbing Forum, Professional & DIY Advice Clean-Out Location Nov 2, 2009
Plumbing Forum, Professional & DIY Advice Toilet cleanout location Dec 13, 2007
Plumbing Forum, Professional & DIY Advice Upstairs Cleanout location Feb 24, 2005
