Locating automatic sprinkler control valves
Discussion in 'Irrigation / Sprinkler Forum' started by nervona, May 23, 2007.
  1. nervona
    nervona New Member
    May 23, 2007
    Is there any way of locating sprinkler control valves in the yard? I have purchased a home with an automatic sprinkler system and didn't think to ask about the locations of the control valves. I have an 8 zone system and have located 5 of the control valves (each are in a different location around the house). One of the zones has a very weak flow and I am wondering if the valve isn't opening all the way. It seems to have the same number of pop-up sprinklers as the other zones and all the other zones have great pressure. I've poked a stick into the ground in places I think the valve box ought to be, but can't seem to find it. Any suggestions?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I would suspect it is near the controller. Otherwise there would have to be a conduit with wires from the controller to the valve box. Try to determine where the wires run when they leave the controller. The only other reasonable possibility is the valves may be close to the water source. Of course, reason does not alway apply.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
  5. numedpick
    numedpick New Member
    Jun 13, 2007
    I had this problem recently and casually asked a sprinkler guy that was working on the neighbors system for help. Took him no more than 5 minutes to locate for me and I gave him a $10 bill. Plus he will get any future business that I can't handle. Those locator devices are the way to go.
  6. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
  7. ToolsRMe
    ToolsRMe New Member
    Mar 12, 2006
    CO
    In my house the water tees in the crawl space. Therefore I have two backflow preventers.
    Thus I had a set of six valves on one branch of the tee and three on the other.
    Also look for the controller wire. On my house the wire ran along the exterior wall so that it was minimally exposed.
    In terms of weak flow, in my system there were leaks. The HD guy said (for whatever it is worth) that it is unlikely to be a bad valve. Nonetheless, it is easier to replace a vale than to find a leak.
    In my case, I replaced the vale and then still had to find the leak. The leak was under a concrete patio. Fixing the leak was definitely not fun.
Similar Threads: Locating automatic
Irrigation / Sprinkler Forum Advice on locating Reduced Pressure Backflow Assembly in my Basement Jan 16, 2015
Irrigation / Sprinkler Forum Locating Valves Jun 1, 2011
Irrigation / Sprinkler Forum Locating Zone Values Jul 3, 2008
Irrigation / Sprinkler Forum Yard hydrant/automatic horse waterer question Sep 5, 2016
Irrigation / Sprinkler Forum automatic sprinkler valves May 1, 2013
