Load calculation?
Discussion in 'Electrical Forum discussion & Blog' started by Nate R, Dec 21, 2007.
  1. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    Going through load calcs for my house w/ proposed addition, as I'll be getting a new main panel before the addition.
    Wondering how I calculate the load of a garage? Not a workshop, no living space, just a standard garage used as an average garage. General lighting load of 3W/SF? Less since it doesn't have/need much light?
  2. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    Electrical Contractor
    Unless you have a specific load that needs to be served, there's no additional calculations needed for the garage.
  4. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    Excellent, thank you!
    So, once I do the load calculation, is there a NEC mandated additional amount of ampacity required? (IE: If my load calcs came up with 62 AMPs, does NEC say I need 62+20% minimum for service?)
    I did come up with a little over 60 amps. Not too much load when the dryer, WH and stove are all gas. I currently have 100 AMP service and don't see EVER adding any more high load items than what I calculated for. I doubt we'd ever add a hot tub, no reason to go to Electric WH or Stove.
    I'll need to move the service drop when I do have the panel upgraded. But that fun will come later.
  5. 480sparky
    Oct 8, 2007
    If you calculated 62 amps, you only need a minimum of a 100a service. 230.79(C).
  6. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    Thanks again! I'll have to order the 2008 NEC book before I get into doing any of the electrical work.
  7. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    You need to do the electric work per the NEC that is being utilized by te local jurisdiction at the time you build. But you can always wire what some call code plus. all GFCI all AFCI ect.....but check with the local jurisdiction to see what NEC is presently in use in your area.
Similar Threads: Load calculation
Electrical Forum discussion & Blog Help with load calculations... sanity check Mar 15, 2016
Electrical Forum discussion & Blog No Idea how to do a load calculation. Jan 1, 2008
Electrical Forum discussion & Blog Extension ring for ITE EQ Load center Nov 12, 2016
Electrical Forum discussion & Blog GFCI tripping with no load when connected to power Oct 7, 2016
Electrical Forum discussion & Blog Running a 36amp load on a 40amp breaker Sep 15, 2016
