Little water is coming out of my newly installed kitchen wall-faucet. Help?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hotrod79, Nov 17, 2008.
  1. hotrod79
    hotrod79 New Member
    Nov 17, 2008
    I'm new to these forums and I'm looking for as much help as I can get.
    I recently replaced an old wall-mounted kitchen faucet because the cartridge for the cold knob broke or popped out. I later learned that I can just replace the cartridge and didn't need to replace the entire faucet BUT I guess it's okay since my landlord is going to reimburse me anyway.
    I'm new at this and never done it so please bear with me. Anyway, I installed the faucet and turned on the main water valve and hardly any water comes out of the faucet.
    The faucet I purchased looks like the attached picture:
    Every other faucet in the house is running normal and I tried uninstalling the faucet and run the main water valve to see if the pipes are clogged, that wasn't the case.
    I don't know what else to do, the new faucet instruction manual and the instructions from the back states that the installation of the faucet is as easy as 1-2-3, "No special tools required and no experience needed."
    What am I doing wrong?
    Thanks in advance.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Unscrew the aerator and check it for debris.
  4. hj
    IF the flow is the same regardless of whether you open the hot, cold, or both, then the aerator is plugged. And since this is a rental unit, why were you working on the faucet in the first place? The owner could tell you, "Tough, I didn't tell you to try to fix the faucet, and I did not tell you to replace it." And if he did do either of these two things without knowing if you were capable of it, which is now questionable, he was "unwise".
Similar Threads: Little water
Plumbing Forum, Professional & DIY Advice Little to no Pressure Hot water side Mar 8, 2016
Plumbing Forum, Professional & DIY Advice DHW tank above all fixtures very little hot water Jul 9, 2015
Plumbing Forum, Professional & DIY Advice Needing to splice into a water line in the attic. a little help please? Mar 18, 2011
Plumbing Forum, Professional & DIY Advice little flow of water Jun 20, 2009
Plumbing Forum, Professional & DIY Advice Bathroom replumbed - little hot water in sink Mar 8, 2008
