Like a slot machine...
Discussion in 'Toilet Forum discussions' started by hammy233, Jul 6, 2005.
  1. hammy233
    hammy233 New Member
    May 7, 2005
    Hi...my flush is like a slot machine..sometimes you win, sometimes you loose...I think my toilet may be in the wrong end of the house, I`d say half or more times the toilet gets flushed it needs to be flushed again :eek: ..it doesn`t quite get that "suck" :eek: .....I am on a septic system, the the house is just 2 years old we bought it in April, the toilet waste line runs almost 2/3 the way back the other direction with an ever so slight downward slope to a 45 a section then a 45 then straight down in the floor and out to the tank, the tank was pumped before we moved in. Is there a way or solution to getting the "Krud" :( to get movin in the waste line..i.e. pressure assist toilet, any idea would be appreciated.
  2. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    Hit the jackpot!
    It's probably not your pipes, it's your toilet.
    But you could take the toile off and look at the pipes and push a snake in to see if there are any obstructions.
    You could snake the toilet first to make sure there isn't something stuck in the actual toilet.
    But assuming those are clear, you probably just have one of the many low flow toilets or an old high flow low performance toilets that don't work. If the pipes are clear, buy a Toto Drake and you'll hit the jackpot on every pull
    TOTO Drake 800 grams by Veritech, Video
  4. jadnashua
    Getting the stuff out of the bowl is dependent on the quality of the design...even some of the power assist toilets don't rate high. Terry has some test results showing performance. Pick a toilet near the top of the list, and you shouldn't have problems. You might be able to see how yours stacks up (but they don't test every model). Once it is in the waste line, if the slope is proper, it will flow where it needs to unless obstructed.
  5. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I have a Crane Economizer pressure-assisted toilet. It has NEVER clogged, never needed plunging --
    but does require double flushing about half the time (for solid waste).
    If I replaced it today, I'd go with a Toto product.
  6. smhowell
    smhowell New Member
    Apr 2, 2005
    Oklahoma
    I installed a Toto Ultramax last year. It has never clogged and has only needed a double flush maybe twice.
  7. hj
    toilet
    IF the toilet doesn't flush the first time, but does the second time, and does it consistently, then the toilet usually needs an adjustment.
  8. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Flush
    Make sure there is enough water in the tank to fill to the level marke. If the refill tube is not going into the tanks overflow or if it's plugged this can happen. 1. Every other time the toilet gets flushed the toilet bowl is in need of more water(is low on water) and because it didnt flush well there will be more water left in the bowl(nearer the natural overflow level)
    Check the refill tube.
    Find a toilet like yours and take away the refill tube and then flush the toilet with paper.
    It makes a difference.
Similar Threads: slot machine
Toilet Forum discussions 2 Slot Cast Iron Flange Question Nov 17, 2007
Toilet Forum discussions Closet Flange Cracked Along Bolt Slot Jul 31, 2006
Toilet Forum discussions Which slot in flange to use? Apr 24, 2005
Toilet Forum discussions Washing Machine vs Toilet Oct 2, 2006
Toilet Forum discussions Draining tub or wash machine sucks water out of toilet,HELP?...Please! Jun 9, 2006
