Lights out
Discussion in 'Electrical Forum discussion & Blog' started by gbsk, Jun 18, 2009.
  1. gbsk
    gbsk New Member
    Nov 22, 2008
    Alaska
    lights out
    About 8 years ago I installed some track lights on 2 sides of our ceiling. The
    lights are about half way up both sides of our 20 foot A frame ceiling. I know
    when I installed them I installed a breaker for each set of lights. Each side
    has 3 lengths of 3 65 watt lights so it would be 585 watts on each side.
    Gradually the lights went out on one side. About 2 years ago, I tried to
    replace the burned out lights and none of the replacements worked. The last of
    the the lights went out about a month ago. I was in the room and the last 3
    went out at the same time. I tried to replace the lights on that side and none
    of the replacements worked there either. I know I had breakers that could
    handle the wattage on each side. Does anyone know why the replacements won't
    work? Does anyone know what may have gone wrong and what to do about it?
    Thanks
    GB
  2. jadnashua
    Are the lamp fixtures line voltage or low-voltage? And, if low-voltage, where is the transformer?
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Cheap heads = burned sockets/wires?
    Take the heads down and clean/inspect/continuity test them.
    Check power at 6he switches/dimmers
Similar Threads: Lights
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
Electrical Forum discussion & Blog 3 recessed lights, switch at end? May 9, 2015
Electrical Forum discussion & Blog Retrofit Recessed lights with LED Dec 3, 2014
