Abouthadit
Ok the electrician showed up , first thing he wanted to do was check the panel, coarse he worked on the city side for about 30 minutes (he use to work for the city) He checked what he could, removed the main wires coming in , tightened the panel brackets that hold the main wires, then he removed a few breakers and then removed the main breaker 100/100 and the contacts were rough pitted as in had arced ?
He called the city and one of the guys that he trained showed up and he took off the meter and checked the contacts behind it and they were good.
He replaced the main 100/100 breaker and put everything back together, I came inside turned all the lights on and started up the WM , the lights didn't dim/flicker at all.
So far so good , hopefully that did it !
