Lighting outdoor takagi
Discussion in 'Tankless Water Heater Forum' started by HANK WHITE, Nov 19, 2011.
  1. HANK WHITE
    HANK WHITE New Member
    Mar 10, 2010
    redding calif
    GUYS;
    So here I am in winter, it's raining, 42 degrees, and the stinkin' Takagi TK3 outdoor propane water heater won't light off.
    I get gynormously frustrated, go to the barn, and return with an old electric room heater. I aim it at the Takagi from 2 ft
    below it in the screen porch where it lives, and turn it on. It warms that Takagi and its' pipes up to about 60-70 degrees in
    5 minutes or so, and Voila! hot water, Takagi runs normally, wife is happy. It is so stupid to have to warm up a water heater
    to get it to turn on and make hot water. This functional fix is truly 'Hillbilly' in all its' grandeur. It's the only good fix so far.
    Can anybody out there beat this junkyard fix??
    Hankster
    Redding, Ca.:rolleyes:
  2. mtcummins
    mtcummins In the Trades
    Jun 25, 2010
    General Contractor/Property Manager
    Pittsburgh PA
    I can't say I know anything about an outdoor water heater. We all have our heaters in basements here in PA. It seems to me that an outdoor water heater has lots of potential problems... is there any real benefit other than not taking up space inside a house w/o a basement?
    Can it go in the attic? I know a lot of southern homes w/o basements do that... it would at least be a little warmer, though not much if your attic is properly insulated and vented.
    Obviously those are bigger jobs requiring major replumbing and probably not what you're looking for. Can the space be enclosed, insulated, and partially heated by the house's heat? Make sure the venting is done properly if you go that route...
    Also, why is your heater not working in only 42 degrees? That seems like a malfunctioning heater to me, but again, I know nothing about outdoor heaters.
    This is probably completely unhelpful, but I'm curious as to the answers others might give too...
Similar Threads: Lighting outdoor
Tankless Water Heater Forum Rinnai RU98 propane outdoor Oct 2, 2015
Tankless Water Heater Forum Takagi outdoor propane tankless tk3 Nov 10, 2011
Tankless Water Heater Forum Clearances for outdoor mount unit Jan 18, 2010
