Light Switch to turn on wall outlet
Discussion in 'Electrical Forum discussion & Blog' started by coopns, Feb 7, 2010.
  1. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    I installed new white light switches and wall outlets but the light switch does not turn the light at the outlet. I thought I remember someone saying something about breaking a tab tab but it is unclear. Could someone explain/pics?
    Thanks.
  2. jadnashua
    Assuming you have a duplex outlet, and you want one hot all the time and the other switched, you need to break the tab on the gold (brass) side to separate those two hot connections. Then, you attach one constant hot lead to the outlet you want always hot, and the switched hot lead to the other gold contact. At the neutral side, you typically only have one white wire, and leave the tab connected so each side gets the neutral. If you broke the tabs on both sides, you need to add a jumper to reconnect them. This is often best done by putting two short wires on the original neutral with a wire nut, then screwing the two pigtail leads into the receptacle's screw contacts. The same idea if you switch both outlets separately, one switch's hot would go to one brass screw and the other to the second.
    Is your problem that it is always on, or never comes on?
  4. hj
    You must have done something at least partially right, otherwise you could have tripped the circuit breaker everytime you tried to turn the light on. Follow the previous directions for removing the "jumper tab" between the two "hot" terminals. That should be all you have to do, unless you miswired something.
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Was there a red wire in one of the receps?
Similar Threads: Light Switch
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Light switch with pilot Nov 25, 2016
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
Electrical Forum discussion & Blog Three Way Switches Light Dimmer Installation May 1, 2016
