Light switch outside Bathroom and more..
Discussion in 'Electrical Forum discussion & Blog' started by Rocknroj, Feb 27, 2009.
  1. Rocknroj
    Rocknroj New Member
    Dec 30, 2008
    My bathroom is to the studs and gets new wiring and plumbing.. The old light switch was in the hallway, the fan switch inside the bathroom. Are there restrictions on placing the main light switch in the bathroom?
    Should the light switch be GFCI protected. I am thinking one 20 amp circuit for the main light/fan combo (2 switches), a light above the vanity (separate switch) and an outlet near the vanitity. Can I run all these on one circuit with a gfci breaker at the box? That way everything is protected. Seems like that should be more than enough unless someone trys to run a table saw and shave at the same time.. HA!
    And finally.. Any restrictions for switch and outlet replacement near the vanity. I am thinking about placing the outlet and switch for the vanity light about 6 inches above the vanity near the right edge..
    Thanks in advance for your thoughtful response.
  2. drick
    drick In the Trades
    May 16, 2008
    YES! Don't place it in the shower:) And ideally not within easy reach of the shower. This can be hard to accomplish sometimes.
    Only if you are planning on dropping it in the sink.
    (NEC 210.11C3) The 20 amp circuit can only serve both the lighting and receptacles as long as this circuit ONLY SERVES THE ONE BATHROOM. No need for the $$$ GFCI breaker, just use a GFI outlet.
    (NEC 210.52D) "At least one receptacle outlet shall be installed in bathrooms within 3 feet of the outside edge of each basin." Your good.
    -rick
  4. hj
    switch
    If you put the switch outside in the hallway, also place an "occupied/available" sign so passersbys do not turn the light off while you are in the room.
Similar Threads: Light switch
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Mar 19, 2017
Electrical Forum discussion & Blog Lights will not turn on using 3 way switch Mar 5, 2017
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Light switch with pilot Nov 25, 2016
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
