Light in crawl space
Discussion in 'Electrical Forum discussion & Blog' started by khayes, Nov 13, 2009.
  1. khayes
    khayes Member
    Oct 25, 2005
    Alpharetta, GA.
    I want to install a single light in our crawl space with a switch near the access door. I want to tap into a line feeding a receptacle to the room just above the crawl space. The circuit is 20amp/#12Guage. Is it allowable to run a #14G leg off that circuit for the new light?
    Thanks for any advice.
  2. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    No. It must be #12 wire.
  4. jadnashua
    No, as I understand it. ANy wire up to the fixture must be sized for the protection device it is connected to (it can be larger, but not smaller). So, on that 20A circuit, you'd need to use 12g wire. There may be an exception...see what the pros have to say.
  5. khayes
    khayes Member
    Oct 25, 2005
    Alpharetta, GA.
    Thanks guys - that's what I suspected.
  6. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Here is an official answer to that very question...
    http://www.inspectorsjournal.com/Forum/topic.asp?TOPIC_ID=10538
    And always best to ask your local electrical inspector. Local areas can modify the national rules as they see fit.
    My personal opinion is that it is best to use all 12 ga. wire on a 20 amp circuit. (Be consistent in the wire size used for each circuit and that it be of the appropriate size for the breaker on that circuit.)
  7. Cass
    Cass Plumber
    Nov 12, 2005
    You can use a larger wire size than the breaker that is feeding the circuit but you can never use smaller...using smaller is a fire waiting to happen...
Similar Threads: Light crawl
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Vanity Lighting Issue Jan 7, 2017
Electrical Forum discussion & Blog High Bay Light 720W Dec 15, 2016
Electrical Forum discussion & Blog Light switch with pilot Nov 25, 2016
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
