Light in a shower?
Discussion in 'Shower & Bathtub Forum & Blog' started by ingeborgdot, Apr 3, 2008.
  1. ingeborgdot
    ingeborgdot New Member
    Mar 3, 2008
    Kansas
    What special things does a person need for a light in a shower?
  2. jadnashua
    A wet rated fixture...
  4. ingeborgdot
    Mar 3, 2008
    Kansas
    What do you consider a wet rated fixture? The inner housing or the light cover?
    I have the halo H7ICAT with the 172PS outer fixture.
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    You actually only need a damp located fixture, wet location only if subject to shower spray... Sooo, if you want a recess fixture, find a trim that you like that is listed as a damp location....
  6. ingeborgdot
    Mar 3, 2008
    Kansas
    I will be putting the light on my rear wall facing the shower spray so the shower spray will be hitting it directly.
  7. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Then you will require a WET location fixture... so make sure it is listed as such.
    This is a typical wet location fixture... good luck finding something you like. :D
    [​IMG]
  8. Cookie
    Cookie .
    Oct 7, 2005
  9. ingeborgdot
    Mar 3, 2008
    Kansas
    That really was a joke to see what everyone would say.
  10. Cookie
    Cookie .
    Oct 7, 2005
    Well, you do know that people with low vision do put lights in their showers.
  11. Cass
    Cass Plumber
    Nov 12, 2005
    theseplaced around your head work well, and you can't get shocked :)
    [​IMG]
  12. ingeborgdot
    Mar 3, 2008
    Kansas
    I will have a light in the shower but not on the wall. It will be up in the ceiling and no water should hit the light. If it does my light fixture after looking carefully is wet location rated.
  13. ingeborgdot
    Mar 3, 2008
    Kansas
    I have a question about the light fixture that I have chosen to put into the ceiling of the shower. It is made by Halo and it is the 172PS model. It is wet rated. No instructions came with it and I am not for sure how it goes in. It looks like it has a place for the clips that are in the upper part of the housing and two spring loaded clamps that looks like you squeeze together and insert and the tension keeps it up. I am not sure. Does anyone know the proper procedure? I hate to sound so stupid but I have never used one of these before.
    Do I remove the ceramic light socket from the housing parts that are holding it and remove the adjustable holder that comes with the housing? Then do I slide the spring loads up into the light housing? Anyones help would be greatly appreciated.
  14. ingeborgdot
    Mar 3, 2008
    Kansas
    I figured it out.
  15. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Musta been easy... It only took ya a couple of hours. LOL
  16. ingeborgdot
    Mar 3, 2008
    Kansas
    I just hadn't had a real chance to look it over. It took me a couple of minutes actually after looking at the fixture.
  17. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
  18. ingeborgdot
    Mar 3, 2008
    Kansas
    By the way where did you find these? I really do need a pair.
  19. jadnashua
    Most any sporting goods store will have various headband lights. REI, EMS both have websites. www.rei.com (recreational equipment supply) www.ems.com (eastern mountain sports). Both of those have limited retail locations...there might be one near you.
Similar Threads: Light shower
Shower & Bathtub Forum & Blog Steam shower lighting options Dec 20, 2014
Shower & Bathtub Forum & Blog Foam gasket for shower light fixture? Oct 27, 2014
Shower & Bathtub Forum & Blog Installing Luxury Showers on Airplanes and Private Yachts: Using Light Weight Marble Nov 10, 2013
Shower & Bathtub Forum & Blog Is shower stall ceiling lighting required in a new renovation shower? May 7, 2012
Shower & Bathtub Forum & Blog Shower Bench Ideas - Using Glass and Light (LED) by Christa Young of TY Designs Feb 14, 2012
