lever on the side of a pitless adapter?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ccegfa, Sep 20, 2012.
  1. ccegfa
    ccegfa New Member
    Sep 15, 2012
    new haven, IN
    I plan on pulling my submersable pump [4" in a 5" casing well depth 55'] it has a pitless adapter and what looks like a spring loaded lever at that point touching the opposite side of the casing from the pitless adapter. I have been reading about pitless adapters and talk about a release cable from a spring loaded pitless adapter. My well does not have a release cable on this, so how do i release the spring loaded lever or is that not needed---and just pull it out? I am afraid that if i just pull up and that lever wedges aginst the plastic well casing it will split the well casing. Should i make some kind of hook rod to pull up on that spring loaded lever as i pull up on the t-handle when removing it all? I have google sherched pitless adapters and do not find any with a spring loaded lever on the side, that i can look at, but many people talk about them in forums and say "pull the release cable" but without one on mine how can i pull it and what if i dont? Does this lever lock the pitless adapter so it don't come off or just pushes the pipe over so it is easier to connect, when re-installing the pump assembly? [it is not a 3 prong crows foot like some people have talked about]
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If it's not 3 toed and there is no release cable then it likely is the type with a set screw cam that needs to be unscrewed.
  4. ccegfa
    ccegfa New Member
    Sep 15, 2012
    new haven, IN
    where do i look for the set screw, it is almost 5 foot down there, and how do i get a screwdriver that far down if i can find it? i was thinking it is just spring loaded lever to keep the pipe aginst the casing while it is being lowered down in the well so the pitless adapter will mate, but i am afraid if i am wrong and it is some sort of latch that keeps the pitless adapter together and needs to be released before i try to pull the pump, and do start to pull the pump without releasing it, i may break the plastic well casing. if it really is a latch lever, do i take a rod and push it down or pull it up to release it---then pull up on the pump T handle to bring the pump up?
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Take some pics with a good camera that can zoom.
    You don't use a screwdriver, you use a long pipe with a socket on the end that fits inside the larger pipe used to pull the pitless. If you search this forum you will find other threads on it complete with pictures and drawings.
  6. ccegfa
    ccegfa New Member
    Sep 15, 2012
    new haven, IN
    It is hard to search and find the right one in this forum, but i found it under "another pitless adapter question" by "mortal798" he had the same thing made by Merrill mfg at http://www.merrillmfg.com/product/02-PitlessUnits/SMCK-Steel/parts.php#Text with this forum and finding the mfg site i was able to figure it out. boy this must be a off brand as i could not find much about it anywhere. I am glad i didn't just jerk it out, probably would have broken something.
  7. Daniel Earl Keith
    Daniel Earl Keith New Member
    Nov 16, 2012
    Illinois
Similar Threads: lever side
Plumbing Forum, Professional & DIY Advice Toilet arm lever is too big to fit Jan 11, 2017
Plumbing Forum, Professional & DIY Advice The lever (single )on the washer machine shut off valve is missing Dec 10, 2016
Plumbing Forum, Professional & DIY Advice American Standard Single Lever drip behind cartridge Dec 1, 2016
Plumbing Forum, Professional & DIY Advice Cantilever seal and insulate prior to finishing basement Oct 7, 2016
Plumbing Forum, Professional & DIY Advice No brand toilet trip lever Oct 2, 2016
