trevorn
Hello all!
I bought a Mirolin Sydney bathtub. It has 5 wooden legs underneath, and is an alcove model with an apron and tiling flange.
Manufacturer instructions say to use hardwood shims and/or trim the legs to level the bath on an uneven floor. I tried using shims, which puts the apron off the ground by the time it becomes level, which makes the bathtub unstable. So it looks like I'll have to trim some of the legs to make it work... The instructions also say that the installation is incorrect if any of the legs are not touching the ground.. My problem is when I trim the legs, the apron likely still won't be touching the ground across the front since the floor isn't level in that direction.. Is it better to have the tub sloped a bit extra towards the drain to have the apron flush with the ground, or have it perfectly level, and have the apron off the ground? Would I then have to shim the apron so that it's stable or any other suggestions?
Thanks.
Trevor
Thanks.
Trevor
