Letting pipe dope sit before pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edwardh3, Jan 5, 2008.
  1. edwardh3
    edwardh3 New Member
    Jan 5, 2008
    South Carolina
    The Ace hardware can of "paint on type) pipe dope I have says to let it sit 48 hours before applying pressure.
    would this apply to drain fittings also?
    48 hours seems long
  2. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I would not use pipe dope that required a setting time. Tephlon paste from oatey or rector seal for gas or water. Check any paste for use with plastics and PVC.
    Setting type pipe dope gets hard and cracks, unless you are talking about some kind of solvent cement. Pipe dope is for threaded connections.
    What is your application?
  4. hj
    48 hours
    If the pipe dope required 48 hours before pressurizing it, you can be sure that no one would buy or use it. Probably a CYA memo from some engineer/lawyer that wanted an "out" if the stuff failed because he could be sure that no one would follow the requirement.
  5. edwardh3
    edwardh3 New Member
    Jan 5, 2008
    South Carolina
    ace sells tons of it
    green stuff in small cans- no not pvc cement, but pipe dope.
    Is rector seal better (I think this is their generic for rector seal)
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Just get the Oatey that is called Pipe Dope. No fancy schmancey type this or that. But, this stuff is for threaded pipe, not PVC connections like a P trap.
Similar Threads: Letting pipe
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Feb 15, 2017
Plumbing Forum, Professional & DIY Advice PEX Pipe in attics? Feb 14, 2017
