Lets' talk grout type
Discussion in 'Shower & Bathtub Forum & Blog' started by boardable, Nov 12, 2012.
  1. boardable
    boardable New Member
    Sep 27, 2012
    San Jose, Ca
    So I am getting ready to grout my shower plan floor. Used botik eurothane grout on the walls and it turned out great. For the floor they did not have my color in a eurothane grout so now I am stuck with either using the same regular sanded grout I am using on my floor or using a epoxy grout from home depot. I like the eurothane grout because it helps in the water proofing. Does the epoxy grout do the same or is does it still absorb as much water as the regular grout. I just cant get the picture out of my head of water absorbing through the regular sanded grout. Yup loosing sleep lol.
  2. jadnashua
    First, a properly built shower is waterproof BEFORE the tile is installed, so the grout type used shouldn't be a big consideration except for durability and reliability. Epoxy grout is a waterproof plastic, so no, once cured, it is not affected by water. Cement based grouts are somewhat porous and a sealer helps keep them clean. An epoxy grout does not absorb any sealer, so it's not useful.
  4. boardable
    Sep 27, 2012
    San Jose, Ca
    That is what I am wondering. PLus I used a kerdi pan and flood tested but like I said it is keeping me up at night. Also the fact that the foam may be a little flexible makes me want to use epoxy as well.
  5. jadnashua
    When you spread the load out with the tile, denting the foam pan is not an issue at all! Epoxy grout requires careful cleanup (well, any grouting does, but epoxy is much harder to clean after it cures). Epoxy also tends to be a little shiney, which may or may not be an issue. Regardless, I'd go with either a conventional cement based grout or an epoxy. the epoxy shouldn't need any maintenance after installation, a cement based one will last as long or longer, but to look good, you likely would need to clean and seal it periodically. Depends on how much use the thing gets and the type of soaps and shampoos you use. Sealer won't waterproof the grout, but it helps prevent staining.
  6. boardable
    Sep 27, 2012
    San Jose, Ca
    Yea I think I am going with the epoxy. Cleaning grout is not apealing to me.
Similar Threads: Lets' talk
Shower & Bathtub Forum & Blog Generals or specifics talks with John Whipple -- showers , waterproofing....... Jan 4, 2014
