Lennox / Copeland AC Compressor
Discussion in 'HVAC Heating & Cooling' started by 72lemanscvbl, Aug 11, 2010.
  1. 72lemanscvbl
    72lemanscvbl DAVE
    Jul 4, 2010
    Omaha
    I've got a Lennox M/N HS29-060-1p AC with Serial number 5899M43648
    First installer says air compressor is bad and am waiting on a replacement with a verbal install price of $1800.
    Now waiting for the part to come (cant tell us for sure when it will be in) and have called a couple other Lennox retailers , one indicating that Lennox cross references a Copeland compressor. 1st Lennox says that Copeland may require a retrofit and is not of as good of a quality. Is this true? My other calls are saying $2100 and up to $2500 for install. Apparetnly the Copeland is readily available, and the Lennox compressor is "on its way." Any feedback on the Copeland vs. the Lennox?
    AC went out Sunday, Omaha NE, Humid and 96-97 degrees again today. So hoteling it.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    It is not an AIR compressor, it is just "the" compressor.
    Lenox does not make compressors. The original might have been a copeland, a bristol, or a tecumseh. As long as the specs are matched up, any good compressor will be a good replacement. Depending on the tons...a replacement compressor will cost the installer between $400 and $800. About 20% more if it is a scroll rather than a recip. And if you buy the Lennox OEM compressor, add a couple hundred.
    Depending on the failure mode, replacement could be easy, or if you had a burnout or something, a complete flush, evacuation, and replacement of several pounds of R22 at $10 to $30 per pound , may be needed. I would guess the job would run a couple of hours to 3 or 4 hours.
  4. chas22
    chas22 New Member
    Dec 6, 2006
    Oklahoma
    I never buy compressors from Lennox for replacement. I replace with a like compressor and buy an extended 5yr warranty for about the same price as the compresson from lennox.
Similar Threads: Lennox Copeland
HVAC Heating & Cooling Lennox MS7C mini split? any first hand knowledge? Mar 22, 2016
HVAC Heating & Cooling Lennox to Honeywell Thermostat Jan 9, 2015
HVAC Heating & Cooling Lennox Heat Exchanger AC unit keeps blowing the capacitor. Aug 20, 2012
HVAC Heating & Cooling Lennox Furnace not kicking on unless thermostat is turned off then on Dec 26, 2010
HVAC Heating & Cooling Furance fan speed on Lennox HELP Dec 10, 2010
