Lengthining plastic drain pipes, probably a dumb question???????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nelson84, Oct 31, 2010.
  1. nelson84
    nelson84 New Member
    Sep 8, 2009
    Canada
    I need to lengthin a drain pipe for a sink in the wall. I need to add about 8 inches horizontally and then have it come out of the wall to the sink. After cutting the pipe and adding the longer section, do I just smear the glue inside the fitting and on the pipe and stick them together? Is it just one type of glue or do I add some epoxy and another type of glue? What I am getting at is what is the glue that is used to glue the black plastic drain pipes? How much do you use? What is the best tool for cutting the black drain pipe? A sawsall???
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    You need abs glue, put it on the inside of the fitting and on the pipe then push and twist slightly (this spreads the glue nicely) and hold for a few seconds, then wipe the excess glue. The best way to cut abs is with a tube cutter with a plastic wheel, but a hacksaw will do just fine, try to cut as straight as possible and trim off any burrs.
Similar Threads: Lengthining plastic
Plumbing Forum, Professional & DIY Advice How to get hard plastic piece out of the drain? Yesterday at 9:54 AM
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Wednesday at 10:33 PM
Plumbing Forum, Professional & DIY Advice Plastic over exerior drain tile gravel pack Oct 10, 2016
Plumbing Forum, Professional & DIY Advice Plastic connector for sink sprayer won't come off Jul 7, 2016
Plumbing Forum, Professional & DIY Advice Grease in plastic drain pipes - prevention Mar 2, 2016
