lengthing/moving 110V wire
Discussion in 'Electrical Forum discussion & Blog' started by DanMc, Aug 27, 2013.
  1. DanMc
    DanMc Engineer
    Dec 5, 2004
    Engineer
    Georgia
    I would like to add a recessed light, a couple in fact, in the ceiling of my 1st floor study. For a short time I have access from above because the flooring is being replaced on the second floor. The problem i have is that there is a wire, 14/2 nm, running through the joists on its way to a 2nd floor wall outlet and it would end up touching or an inch away from the can. Doesn't feel right. Replacing the whole thing would be very painful as this is an existing install and i do not plan on cutting into 2nd floor walls. Is it acceptable to cut the wire and splice in another 24 inches or so using a junction box at each end and wire nuts? That would be enough to avoid the light can. I think the wire feeds a single 15 amp dual-outlet but there may be two.
    tthanks
  2. hj
    AS long as the junction boxes are accessible, which I an not sure if they would be in your situation.
  4. jadnashua
    What type of can is it? If it's an IC type, since that can be In Contact with insulation, an inch is more than enough. If not, then you'd have to read the spec sheet to see what the minimum spacing to other objects.
  5. DanMc
    DanMc Engineer
    Dec 5, 2004
    Engineer
    Georgia
    Jim: they are not IC cans. The small junction box on the can is at the end of a metal bracket about 3--4 inches long. The box and bracket are an integral part of the can.
    hj: these would be new boxes. I am thinking something like cut the existing wire where it crosses a joist. Then add a junction box on each loose end one joist over. Then i would have to add a new wire between the two. I would have access because i can lift the subfloor for about two weeks before new floors come.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The boxes will have to be accessible after the new floor is installed. It isn't going to look to good with a box cover in the floor.
    I have never seen a light fixture that would be noticed if they were moved three inches away from their original point
  7. DanMc
    DanMc Engineer
    Dec 5, 2004
    Engineer
    Georgia
    jw: ah. I understand. You are correct, to make them permanently accessible would not really be possible in this case without it being really ugly. it seems a different spot may be my only option. was trying to keep it centered relative to some windows and in the same relationship as other lights but that may just not be practical. thanks for the help. I appreciate it. Stupid question, why is permanently accessible a requirement? might stick in my head better than just remembering a rule...
  8. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Everywhere a joint, splice or termination is made is a point on the wiring system trouble can be therefore it must be done in a manner that would allow access to that point.
  9. hj
    quote; I would have access because i can lift the subfloor for about two weeks before new floors come.
    What about after 2 YEARS? That is when you might have problems, not two weeks.
  10. Stuff
    Stuff Active Member
    Mar 7, 2013
    Pennsylvania
  11. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    Dan,
    I have used one of these ONCE.
    I gotta say, they are engineered to a fair-thee-well.
    If you want to ask your local building dept if it is OK to use them in your plan, go ahead.
    But JW has a better idea: move the light slightly. And why not buy Insulation Contact fixtures? They can CERTAINLY be set an inch away from some NM.
  12. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
Similar Threads: lengthing/moving 110V
Electrical Forum discussion & Blog need help-use a 220V appliance in USA 110V Jan 29, 2014
Electrical Forum discussion & Blog 110v off 220v line Feb 10, 2013
Electrical Forum discussion & Blog 220v to 110v Nov 22, 2010
Electrical Forum discussion & Blog Split 110v off a 230v branch circuit? Dec 9, 2009
Electrical Forum discussion & Blog 220v dryer out conversion to 110v? Oct 20, 2009
