Length of Pipe for Tub Spout?
Discussion in 'Shower & Bathtub Forum & Blog' started by dmc, Mar 15, 2006.
  1. dmc
    dmc New Member
    Mar 15, 2006
    I am replacing a 3 valve divertor in my tub/shower and my tub spout has an internal threaded connection to the pipe coming out of the wall. This pipe coming out of the wall needs to be replaced since the tub spout is a different length.
    My question is this...How do I get the threaded pipe to the right length so that when I go and tighten the tub spout it points downward and is flush/tight to the wall?
  2. jadnashua
    The nipples come premade in various lengths. Worse comes to worse, you might get one made, but it needs a special machine, not the standard pipe threading one. You will have a little leaway by using more or less wraps of teflon tape at both the in-wall elbow and at the spout. Unless this is a divertor tub spout, there isn't much pressure, so it doesn't take much to keep it from leaking. If it has a divertor on it, that is not as true. Some of the fittings in those things are plastic, if yours is, don't overtighten it or you could split it. The better ones are metal, but even then it can be split from over tightening.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    use a 1/2 copper male adaptor and sweat 1/2 copper pipe on then you can cut it to the length necessary.
Similar Threads: Length Pipe
Shower & Bathtub Forum & Blog Moen A7250RB Drop Ell pipe nipple length Aug 4, 2010
Shower & Bathtub Forum & Blog Copper pipe length into tub spout? Feb 6, 2010
Shower & Bathtub Forum & Blog Delta MultiChoice Universal valve body (R10000) and length of drop to spout Jun 3, 2012
Shower & Bathtub Forum & Blog Bathtub's ledger edge length Jan 3, 2010
Shower & Bathtub Forum & Blog soaking tubs with long leg lengths Mar 21, 2009
