Ledger board for a Cast iron tub?
Discussion in 'Shower & Bathtub Forum & Blog' started by Andrew21, Apr 11, 2010.
  1. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Hey all,
    I've been reading all the threads and it seems to be a mixed opinion here. When I get my cast iron tub, do I need to install a ledger board? assuming the floor is level? Thanks!
  2. Terry
    Aug 17, 2004
    The ledger board is how many of us install a cast iron tub.
    If the home is not new, put a level on the floor 30" from the back wall to see which part of the floor is high.
    The apron will touch down on the high side, and the low side will need to be shimmed.
    The height of the ledger board is determined somewhat by the high spot you measured.
    The tub must be installed level front to back, or tile will look awful.
  4. hj
    Some, but not all, cast iron tubs have "legs" which fit on the floor, but even with those, a ledger board ensures that the tub ledge will NOT separate from the tile because of expansion and contraction in the wall structure, or settlement of the floor under the legs.
  5. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Interesting. I'm going to install a Kohler Villager tub. I think its one that Home Depot sells.
  6. Terry
    Aug 17, 2004
    We all sell the Kohler Villager.
  7. hj
    It has legs, but I would still install the ledger board, especially if it is NOT going to be installed on a concrete slab floor.
  8. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    I installed the Kohler Villager several years ago. The instructions specifically said NOT to install a ledger - so I didn't.
    http://www.us.kohler.com/onlinecatalog/pdf/1084177_2.pdf see page 3 for the warning
  9. Terry Love
    Terry Love Plumber
    Aug 17, 2004
    Bothell, WA
    You didn't install a ledger board?
    Too bad.
    Plumbers work from experience, not from a desk.
  10. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    No I did not - as per manufacture's instructions. See warning and link above.
  11. Terry
    Aug 17, 2004
    Like I said, experience everytime.
    I've installed hundreds of cast iron tubs.
    I would love to see you find a way to correctly place the shims after you have set the 300 pound tub in place.
    Good luck with that one.
    Have you installed your tub yet?
    How easy was it?
    It's not hard for me.
    And the tile guys love to install behind me.
    Everything is so level.
  12. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    I have installed two cast iron tubs in my home. I'm sure I took longer than a licensed plumber would, but that wasn't important to me. With the first tub, I called and emailed Kohler's tech support and got help from them. And had them verify the ledger issue.
    Shims were easy to install on the first tub as I had open access to 3 sides of the tub (the back side of the tub was adjacent to a closet which was gutted down to the studs during the remodel). Just used a 2x4 from the back side of the tub to lift, then slide in the shims. No sweat.
    The 2nd tub (Kohler Memoirs @350 lbs) was more work as I had to slide it in and out of the alcove a few times before I got it completely level. Even though I had the floor perfectly level, the tub's feet were not. I made little ramps out of wood that lead up to the shims (ramps on both sides to help the back feet move over the shims on the way out - as I had to slide it in and out a couple of times). I marked the floor for the location of the metal shims and nailed around them so that they would not move while sliding the tub in place. Same for the little wooden ramps. Again no problem, took me maybe an hour to get it completely level.
  13. hj
    You really believe some engineer who has NEVER installed a bathtub, actually knows how to do it? They usually do not even write the technical manual that says how to do it. That is usually done by someone has has attended an ETL ("English as a THIRD language"), course.
  14. Terry
    Aug 17, 2004
    Zenman,
    You have all the plumbers laughing.
    This should be put in the joke section.
    No plumber has ever heard of a problem with a cast iron tub cracking.
    As many tubs that I have looked at in the last 36 years, the only thing that ever happens is wear from use and cleaning, and people dropping hammers in them and chipping the porcelain finish.
    We do have problems if they are installed out of level.
    At least the guys installing tile have a problem with it.
  15. Zenman
    Zenman New Member
    Nov 26, 2004
    New Jersey
    Glad I could be of service :D
  16. hj
    Well, you're not THAT funny, so don't quit your day job.
  17. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    I like the advice from the pro's :)
  18. geogymn
    geogymn New Member
    Jan 21, 2010
    ny
    Overkill or maybe just a knucklehead but I put a plastic margarine container filled with freshly mixed grout under each leg just before I prop the tub on the ledger board. I've also used silicone caulk in place of the grout on occasion albeit I don't install that many cast iron tubs. Oh and I would listen to a pro before any installation manual.
  19. TWEAK
    TWEAK New Member
    May 17, 2009
    Bay Area CA
    After seeing the Kohler instructions I called and they said that they wouldn't warranty the tub if it was hung on the lip.Levelling my big Tea for Two tub wasn't really a problem. I rigged a lever to jack it up by the rim so I could slide the shims under the far feet. Easy. And no worries about the warranty.http://www.us.kohler.com/onlinecatalog/detail.jsp?prod_num=850
  20. hj
    You are NOT supporting the tub by its lip, you are integrating the tub with the wall surface. The only way it would be supporting the tub is IF the legs compressed into the floor, and in that case the lack of a ledger board would create a crack betwen the tile and the tub. AND Kohler tubs USED to REQUIRE a ledge board before they started adding feet to the tubs, and they NEVER cracked.
  21. TWEAK
    TWEAK New Member
    May 17, 2009
    Bay Area CA
    Maybe I am not understanding what you guys are referring to, then. Terry is talking about the difficulty of getting levelling shims under the feet, so (as I read it) he prefers installing a level ledger board. For the ledger to affect the level of the tub, the tub lip has to be sitting on the ledger, no? The tub is either sitting on the feet or the lip is sitting on the ledger board. It can't do both. If it's sitting on the feet, then you have to level by shimming under the feet - what good is the ledger doing?
    I can't comment on older models, the current ones with feet are what we are discussing. The local dealer, whose service manager was a former Kohler employee, cautioned that the current models do show hairline cracks in the bottom of the tub, usually around the drain. In fact they were adamant that I fill the tub all the way to the overflow and let it set for a couple of days before installing the tub deck (mine is an undermount) and surround, "just in case". My tub was nearly $2 grand (including their special drain assembly) with almost $8 grand of slab granite deck and surround walls, so it was pretty important to do things by the book and get the Kohler warranty. The service manager even came by the house to look at the installation before the granite went in to make sure that it was all "good" - per Kohler's instructions.
    Again, maybe I don't understand your installation. But I found that that levelling the feet wasn't a problem.
Similar Threads: Ledger board
Shower & Bathtub Forum & Blog Questions on tub mortar setting and ledger board Apr 9, 2016
Shower & Bathtub Forum & Blog Kohler Performa tub - No ledger board? Jul 5, 2006
Shower & Bathtub Forum & Blog New acrylic airtub installation, where to put ledger? Nov 25, 2016
Shower & Bathtub Forum & Blog Kohler "Archer" acrylic: Install guide makes NO MENTION of ledgers. WHY? Jul 13, 2015
Shower & Bathtub Forum & Blog Ledger Jan 29, 2014
