leaky wh from overflow tube
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fast pasquale, Jan 7, 2007.
  1. fast pasquale
    fast pasquale hardwood flooring contractor
    Jan 7, 2007
    Too many to list
    cleveland, ohio
    i have a bunch of rentals and in two of them the overflow tube leaks on the water heaters. Is this as simple as installing a pressure reducing valve?? do i ALSO need to install a expansion tank?? why does this happen.. thanks in advance!
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Rig up a pressure gauge and check the house pressure.
    If it's under 80lbs. just change the relief valve that is leaking now.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The problem could just be a defect TP valve. Simple and cheap to replace. So first check the pressure of your water supply with a gauge. If it is much over 60 psi, you should have a pressure regulator valve on the supply. If you do need a PRV, then you will need an expasion tank too. The PRV creates a closed system which prevents the heated water from expanding back into the water supply and results in a huge rise in tank pressure and trips the TP valve. If the pressure gauge shows normal pressure, then just replace the TP valve.
Similar Threads: leaky overflow
Plumbing Forum, Professional & DIY Advice Leaky trap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Leaky spiral hose for main kitchen faucet pull-out line - fix without replacement? Sep 1, 2016
Plumbing Forum, Professional & DIY Advice Leaky back flow preventer Aug 24, 2016
Plumbing Forum, Professional & DIY Advice Help Replacing Washer and O-ring on Leaky Bathroom Sink Handle Jul 15, 2016
Plumbing Forum, Professional & DIY Advice Leaky handle after I turn faucet off Jan 16, 2016
