Leaky Tub Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by Daniee, Apr 14, 2007.
  1. Daniee
    Daniee New Member
    Apr 14, 2007
    I have an American Standard 3 handle Tub faucet.
    I've replaced the valves and seats with brand new parts for both the cold and hot water as well as for the shower.
    I still have a leak from the hot water. What else could possibly be replaced to make this stop??
    Thanks for any help you can offer.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Take it apart again. See if the washer is loose, of was accidentally damaged on assembly. Verify that the seat surface is perfectly smooth. Actually, take the seat out and reinstall with a wrap of teflon tape on the threads. Be sure to trim the excess tape. This is theoretically not required, but I find it helpful.
    Be sure when reinstalling stems that they are turned to the open position. Otherwise, the washer bottoms out before the stem is tightly secured, thus damaging the washer and possibly the seat.
  4. Daniee
    Daniee New Member
    Apr 14, 2007
    Thanks for the response Jimbo...
    Already wrapped the seat with the teflon tape.
    Are you talking about the rubber washer that gets screwed in at the very end? I had taken it apart again and noticed that that screw did seem to be coming loose. What would cause that?
    I checked the seat several times and it seems smooth to me, doesn't seem to be any notches in the seat or the valve, and the washer seems fine, just seems to come loose.
    The valve was in the open position when I put it back in.
    Any other thoughts?
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    The "bib screw" coming loose is probably your problem. Did you try really tightening it down? If so, maybe you can find another bib screw with a couple more threads at your plumbing supply house. Put in a new rubber washer as well and really tighten it down. Also, if your seat or valve isn't exactly the same as the ones you replaced, you can have this problem.
  6. Daniee
    Daniee New Member
    Apr 14, 2007
    I'm back.... and I'm at my wits end.
    I've replaced EVERYTHING. Every washer, the entire valved, the seat, teflon taped it... tightened the bib screw really really really tight (it's not coming loose anymore) and I STILL have a leak.... a steady one. I'm getting exhausted runnin g up and down from the basement to turn the water off.
    Any other suggestions???? PLEASE????
    I hate to call in a plumber for something like this... a) it should be a simple fix and b) I just don't have the money to bring someone in.
    If anyone has any other thoughts, you have my deepest gratitude!!!
  7. Cass
    Cass Plumber
    Nov 12, 2005
    Occasionally I have a valve that leaks no matter what I do and this means the whole valve needs to be replaced not just the seats and valve stems.
    It will leak due to a crack / problem in the valve body somewhere internally that you may not be able to see.
  8. Verdeboy
    Jun 12, 2006
    Have you tried using a beveled washer? We were just discussing how they are sometimes used when all else fails.
  9. Daniee
    Daniee New Member
    Apr 14, 2007
    Hmm.. Nope haven't tried that. If this works you will forever be my hero!!!!!
  10. Daniee
    Daniee New Member
    Apr 14, 2007
    YESSSSSSSSSSSSSSS!
    It worked!!! It's official - you're my hero! LOL:D
Similar Threads: Leaky Faucet
Shower & Bathtub Forum & Blog Leaky Tub Faucet -- Replace Cartridge? Apr 28, 2016
Shower & Bathtub Forum & Blog PFister, How to deal with this leaky faucet? Dec 2, 2015
Shower & Bathtub Forum & Blog Need help with leaky bathtub faucet - newbie Sep 30, 2013
Shower & Bathtub Forum & Blog HELP!...Leaky Bathtub faucet even after I replaced both cartridges Jul 2, 2013
Shower & Bathtub Forum & Blog Leaky shower faucet, drain that doesn't shut off and improvement in shower control Oct 27, 2011
