Leaky shower
Discussion in 'Shower & Bathtub Forum & Blog' started by tumom2, Apr 11, 2009.
  1. tumom2
    tumom2 New Member
    Apr 11, 2009
    I just purchased a 30 yr old condo and I seem to have a leak under the second floor master shower. A plumber went out and said the leak was caused by NOT having a shower pan. What would be the best and cheapest method to fix this leak problem? I've thought about getting a company (like bathfitter's) to install over the old, but how would i know whether there has been any damage to the floor? I've also heard that places like Bathfitter's are very expensive.
  2. jadnashua
    Is this a tiled shower? A partial tear-out is one way, but once you've gone that far (the pan is the hardest and most complicated), you may just end up tearing the whole thing out. To install a liner, you must tear out the floor and curb and up the walls at least 6" or so, probably a little more. Anything else you do is a patch that has no guarantee of operating properly.
    The floor and wall could have some major rot issues if it has been leaking internally for awhile. You won't know until your tear it up.
    You probably should read the condo by-laws very carefully, some of this may be covered by the association, and they will probably have some say in what's done, especially if it affects the structure.
    For good help on showers, repairs, and replacement, suggest you check out www.johnbridge.com.
  4. tumom2
    tumom2 New Member
    Apr 11, 2009
    Thanks. It's sounding to me like the easiest, fastest and cheapest way to go is to install a complete shower liner. However, is the only way to tell if there's floor rot to start tearing things up?
  5. jadnashua
    Unless yo ucan look at the area from underneath, you'll have a hard time telling from above unless you remove a good portion of the shower whether there is structural damage.
    My personal opinion, there's no good way to seal a surface liner to the drain, and then you'll end up with moisture beneath the liner...think stepping on a waterbed...not good.
    A traditional shower with a liner, starting from the wood subfloor is made up of the following layers: decoupling (often just some roofing felt to keep the deck mud from drying out too fast), a sloped bed of deck mud, a waterproof liner attached to a clamping drain, a second layer of deck mud, then thinset and tile. The clamping portion of the drain is beneath 3 layers...not something you can attach to from above.
Similar Threads: Leaky shower
Shower & Bathtub Forum & Blog Leaky shower head Oct 2, 2016
Shower & Bathtub Forum & Blog Leaky shower... Is this fix correct? Jul 29, 2014
Shower & Bathtub Forum & Blog Need help replacing leaky shower Jan 15, 2013
Shower & Bathtub Forum & Blog Leaky shower faucet, drain that doesn't shut off and improvement in shower control Oct 27, 2011
Shower & Bathtub Forum & Blog Leaky Tub Faucet + Low Shower Head Hot Water Pressure May 27, 2011
