Leaky shower... Is this fix correct?
Discussion in 'Shower & Bathtub Forum & Blog' started by KenSimone, Jul 29, 2014.
  1. KenSimone
    KenSimone New Member
    Jul 29, 2014
    A few years ago we paid someone to remodel our master bath. The shower has started leaking down to the first floor. We called the same company, and this is their fix so far. Is this correct?
    [​IMG]
    [​IMG]
    [​IMG]
    Update: After I complained about the caulk, Lee's Tile in Dallas Texas (the people responsible for this fine job) came out and added some new weep holes for me. Unfortunately, they weep right through the bottom.
    [​IMG] [​IMG]
    Thanks,
    Ken
  2. Terry
    Aug 17, 2004
    That looks interesting..........
    A mud set drain is a clamping drain with a vinyl liner. When the water gets past the tile and grout, the liner picks up the water and makes it through the little weep holes there. Have they flood tested the pan yet?
  4. jadnashua
    The only place silicon is useful in a tiled shower pan is on the under side of the liner to seal it to the clamping drain. This is a hack job. Unless there's a crack in the actual plumbing, the shower should be waterproof before the tile is installed, and silicon is not part of the equation to make it work that way.
    Without some more tearout or knowledge of how the shower was built, there's no way to tell if this hack job will patch things and stop the leaks. Building a tiled shower isn't all that hard, but it is VERY detail oriented, and skipping or messing with any one detail can ruin a shower. IOW, there should be no reason to do what they did if the rest of it was done right!
    The Tile Council of North America (TCNA - the people who wrote the bible on how to tile things) say that 70-80% of tiled showers are not built properly, so unfortunately, you are not alone in having a poorly performing shower.
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Everything so far looks wrong.
    The silicone might have stopped the leak but now your shower will hold back more water.
  6. ShowerDude
    ShowerDude Showers
    Apr 7, 2014
    Minnesota
    Ken my friend. Its time to bite the bullet as they say and take that shower pan down to the rotten moldy plywood and rebuild.
    What you have looks like a bad attempt at a third patch job. How much is this costing you now , in the past, and again in the near future?
    My 2 cents. - redshoe
Similar Threads: Leaky shower
Shower & Bathtub Forum & Blog Need help replacing leaky shower Jan 15, 2013
Shower & Bathtub Forum & Blog Leaky shower faucet, drain that doesn't shut off and improvement in shower control Oct 27, 2011
Shower & Bathtub Forum & Blog Leaky Tub Faucet + Low Shower Head Hot Water Pressure May 27, 2011
Shower & Bathtub Forum & Blog leaky shower door with slate tile Jan 1, 2010
Shower & Bathtub Forum & Blog leaky shower Dec 26, 2009
