Leaky Shower drainpipe?
Discussion in 'Shower & Bathtub Forum & Blog' started by mustaine, Oct 19, 2005.
  1. mustaine
    mustaine New Member
    Oct 18, 2005
    Okay, heres the story. I have a stand up plastic shower in the downstairs bathroom. I noticed that a puddle of water was forming from it into the basement cement floor which is right on the other side of the wall. There is a gap of the wall at the bottom in the basement area where you can see the bottom of the shower. My first guess was that it needed to be recocked. I did that and put the rubber strip tape on it as well to ensure no water would leak out. It still is, and now I assume that the leak must be the shower drain pipe. Not sure where though. I looked down it with a flashlight but saw no cracks. Basically I would like to know what to do next? I am getting some minor mold on the wood in the basement where the leak is occuring, so I def. need to solve this problem very soon. Thanks
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    shower
    Help us to double check exactly what your saying..............
    What is rubber strip tape and where did you put it?
    What does recocked mean? Do you mean caulked or corked?
    If so are you talking about caulking around the base where the walls fit into the base?
    You need to tell us what kind of seal was used to seal the shower base to the 2" drain pipe.
  4. mustaine
    mustaine New Member
    Oct 18, 2005
    the rubber strip tape is available at home depot. It says to put it over your caulking to prevent mildew. Its white and looks good, and mildew doesnt build on it. Recocked meaning "recaulked" sorry about the spelling. I recaulked the shower (the base) and the leak is continuing. And I dont know what kind of seal was used to seal the shower base to the drain pipe. I just grabbed the house last year so I wasnt the person who installed it. Hope that helps you a little better.
Similar Threads: Leaky Shower
Shower & Bathtub Forum & Blog Leaky shower head Oct 2, 2016
Shower & Bathtub Forum & Blog Leaky shower... Is this fix correct? Jul 29, 2014
Shower & Bathtub Forum & Blog Need help replacing leaky shower Jan 15, 2013
Shower & Bathtub Forum & Blog Leaky shower faucet, drain that doesn't shut off and improvement in shower control Oct 27, 2011
Shower & Bathtub Forum & Blog Leaky Tub Faucet + Low Shower Head Hot Water Pressure May 27, 2011
