leaky pvc sprinkler pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fred, Sep 10, 2004.
  1. fred
    fred New Member
    Sep 10, 2004
    I recently saw water gushing out of a hole in the lawn. I cut out a small section of grass for about 4 inches deep and noticed the sprinkler pvc is cracked. I saw your response to a similar posting by a viewer. The response was short and informative about using a coupler but I am not sure how you would get a coupler in line with the pvc tubing when pvc tubing itself is stiff and does not bend. I may have to cut out 6 inches of the cracked pvc.
    I appreciate your full advice. Thanks.
    Fred
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    PVC Pipe Repair
    [​IMG]
    You can cut a section of the piping out, (may need to go more than 6 inches).
    Install two slip couplings, they will slide over the replacement piece then onto the existing buried piping. Make sure to inspect the rest of the exposed piping closely and look for any hair line splits or rocks in the ground that could have caused the damage.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Special PVC fitting
    There is a repair coupler that is made to fix a break like you have. They are available at most any irrigation supply house, but probably not a plumbing supply since this is irrigation stuff. This fitting has pipe ends coming from a center piece. One of the pipes slides into the center a couple of inches or so. You install a coupler on each end of pipe where you cut the break from, install the fixed end into one coupler then slide the other end out and into the other coupler and you're done. In olden times, I patched broken pipes with a U made of 3 short pipes and 4 elbows. The pipe had to be cut quite accurately so all of the pieces would slip together. A real Rube Goldberg looking mess for sure, but it did work. With this new fitting, you just have to get close to the right space. This make is quite easy to repair or tie into an existing line.
  5. jimbo
    jimbo Plumber
    I prefer a "slide-fix" coupling to a repair slip, because the slip couplings do not have an interference fit and I don't like the glue-up performance.
    Slide-fix or similar brand available at box stores and landscape supplies.
    Also, if line is not pressurized main, the so-called Dresser, or rubber compression, couplings work well.
Similar Threads: leaky sprinkler
Plumbing Forum, Professional & DIY Advice Leaky Fire Sprinkler driving me insane Apr 3, 2010
Plumbing Forum, Professional & DIY Advice Leaky trap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Leaky spiral hose for main kitchen faucet pull-out line - fix without replacement? Sep 1, 2016
Plumbing Forum, Professional & DIY Advice Leaky back flow preventer Aug 24, 2016
Plumbing Forum, Professional & DIY Advice Help Replacing Washer and O-ring on Leaky Bathroom Sink Handle Jul 15, 2016
