Leaky Pop-up
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Verdeboy, Dec 20, 2006.
  1. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I replaced one of those crappy plastic pop-up assemblies with a nice, brass one. Taped the threads, puttied the flange, etc.. The threads are still wet just under the brass nut that tightens down the rubber gasket and brass washer. I've already tightened the hell out of this nut. The original pop-up was installed by a "licensed plumber" and was also leaking in the same spot. It had leaked so much, the wet putty was oozing out.
    This sink looks like a normal porcelain lav sink on top, but it has an unusual underside--it looks like stone or clay. I'm wondering if there's a defect or imperfection that is causing this. Will a bead of silicone help here?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    I use pipe dope on the threads above the nut that will be tightened. Enough that the rubber washer has some above it as I am tightning the nut. I never have leaks when I do this but sometimes do when I don't do it.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Pull the nut that you are tightening so much and it still leaks loose and run it all the way down. Now roll a ring of plumbers putty and place it on the bottom side of the lav. drain opening, push the rubber washer and friction ring up and run that nut back up. You will squeeze out excess putty. You shouldn't have to tighten the dickens out of it, just snug and and a little bit more..........
Similar Threads: Leaky Pop-up
Plumbing Forum, Professional & DIY Advice Leaky trap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Leaky spiral hose for main kitchen faucet pull-out line - fix without replacement? Sep 1, 2016
Plumbing Forum, Professional & DIY Advice Leaky back flow preventer Aug 24, 2016
Plumbing Forum, Professional & DIY Advice Help Replacing Washer and O-ring on Leaky Bathroom Sink Handle Jul 15, 2016
Plumbing Forum, Professional & DIY Advice Leaky handle after I turn faucet off Jan 16, 2016
