leaky moen kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thegbees, Sep 20, 2004.
  1. thegbees
    thegbees New Member
    Sep 20, 2004
    hey there. have a 5-6 year old moen kitchen faucet, single handle. i'd guess it was cheapest one the builder could find.
    anyway, it's leaking from the bottom. often the cuff will raise, and the water just pours out. any suggestions?
    in addition, any idea how i can find out what model faucet i have to try to get the old specs?
    thanks
    scott
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Moen Kitchen Faucet
    The faucet cartridge is most likely the one picture here, number 1225.
    There may be some o-rings to replace under the faucet spout, depending on the style faucet you have and the area where the water is leaking from. Moen's homepage has a lot of info.
    ...The parts are probably covered under warranty but they are also cheap enough to purchase at a plumbing supply house or good hardware store.
    [​IMG]
  4. thegbees
    thegbees New Member
    Sep 20, 2004
    i recently changed the cartridge (6-8 mos ago)
    i just found the model online (87130). The leak comes out from below the spout (the spout moves up and down when the water is turned on full blast).
    As a result do you think its the diverter or do i simply change bearing washer?
    thanks
    scott
Similar Threads: leaky moen
Plumbing Forum, Professional & DIY Advice Leaky trap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Leaky spiral hose for main kitchen faucet pull-out line - fix without replacement? Sep 1, 2016
Plumbing Forum, Professional & DIY Advice Leaky back flow preventer Aug 24, 2016
Plumbing Forum, Professional & DIY Advice Help Replacing Washer and O-ring on Leaky Bathroom Sink Handle Jul 15, 2016
Plumbing Forum, Professional & DIY Advice Leaky handle after I turn faucet off Jan 16, 2016
