Leaky faucet; handles won't come off
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by casualfc, Mar 28, 2006.
  1. casualfc
    casualfc New Member
    Mar 28, 2006
    New York
    My bathroom faucet is probably at least 30 years old, compression type. My best guess is that it's a Price Pfister. It's the type with the long white porcelain handles. Right now there's a drip from the spout. This morning it was occasionally leaking underneath on the cold water side.
    The main problem is that I'm able to remove the screws for the handles but then I can't get the handles off to get to the packing nut. What am I doing wrong? I've tried prying up and twisting off but neither seems to work. I'm trying not to force it as it probably just needs washers and I don't want to replace the whole thing.
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    see if you can find a handle puller.
  4. sparking5
    sparking5 Electrician, JIW
    Apr 2, 2006
    Electrician, JIW
    Midwest
    Handle Puller
    Handle puller...is that like an electricians "Pipe Stretcher" or is there really a handle puller tool?
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    handle puller
    A good hardware store or plumbing supply house would have them.
    They last forever and aren't very expensive and you may need to use them again in the future.
    bet you could Google for them.......
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Yes, they are real. Any big box store or hardware store should have them.
    Now if you ever need one I will lend you my pipe streacher as they are very, very hard to find.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    1 trick I have used that has never failed is it to take your torch and slowly, with the flame on and off the handle, heat the handle. Heat it as close to the screw area as possible till it is quite/very hot and the handle will come off. You may still need to rock the handle some.
    If you heat to fast it will discolor the chrome.
Similar Threads: Leaky faucet
Plumbing Forum, Professional & DIY Advice Leaky spiral hose for main kitchen faucet pull-out line - fix without replacement? Sep 1, 2016
Plumbing Forum, Professional & DIY Advice Leaky handle after I turn faucet off Jan 16, 2016
Plumbing Forum, Professional & DIY Advice Help Needed with Leaky Outdoor Faucet Sep 24, 2015
Plumbing Forum, Professional & DIY Advice Leaky Legend outside faucet vacuum breaker May 12, 2014
Plumbing Forum, Professional & DIY Advice Leaky Delta Kitchen Faucet Apr 17, 2014
