leaks only when shower is on?
Discussion in 'Shower & Bathtub Forum & Blog' started by djwoody, Mar 9, 2008.
  1. djwoody
    djwoody New Member
    Mar 9, 2008
    I have a single teardrop control bath and shower,but it only leaks when the shower is on and not when using the bath tub, could it be just the diverter valve? thx alot for your help all
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    shower arm
    try to take out the shower arm screwed into
    the wall and re-tape and grease it back up
    most of the time it has somethign to do with that joint...
    you can also capp of fthat line and turn on the pressure to
    see if you have any other leaks
  4. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    In cases like this, I always inspect the plumbing first without being too intrusive and then check the tils and grout, especially where the tils meet the tub, The tiles and grout have a tendency to fail at any time
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Try removing the escutchen on the valve and operating the shower. this will allow you to see if the leak is from above, at the valve, and is probably the least destructive vantage point. Do you have a diverter on the tub spout? Do you know the make/ model of this valve?
  6. hj
    leaks
    It depends on WHERE the leak is, not so much when it leaks. During a shower there is more back pressure on the valve so if there is a bad seal, it could leak then but not when the tub is being used. No way for us to tell without being there and seeing it.
Similar Threads: leaks shower
Shower & Bathtub Forum & Blog Need help identifying shower valve (leaks) Sep 14, 2014
Shower & Bathtub Forum & Blog New shower enclosure leaks at wall / base Nov 9, 2013
Shower & Bathtub Forum & Blog Help! My Sterling shower leaks! Dec 17, 2012
Shower & Bathtub Forum & Blog Zipponi Thermostatic shower valve leaks between hot and cold Aug 22, 2012
Shower & Bathtub Forum & Blog Rough in shower install leaks May 6, 2012
