leaks in shower and tub pvc pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by caugie, Dec 7, 2006.
  1. caugie
    caugie New Member
    Dec 7, 2006
    Please help, I have no idea what Im doing. My fiance fixed the pvc pipe to the shower and now it is leaking. We have a tub but opted only to use the shower so he sealed off the pipe to the tub faucet, all the pipes have been leaking since he installed them. Now the pipe to the shower sprays water whenever the water is turned on. He used pipe dope and glue and tightened it very, very tight. What is the problem and how do I fix it? Please help, I need to put my wall back together......lol
  2. Cass
    Cass Plumber
    Nov 12, 2005
    It sounds like you are desprate and just want it fixed.
    If I were In your predicament and situation I would call a plumber.
    They can come out and fix it fast by the sounds of what needs to be done.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Can you post a picture showing where it leaks, and what you want to do?
    I can't imagine that you want to have a tub installed with no way to run water into it excpet through the shower. It may be ok for you but will be a problem if you ever want to sell. Now that the wall is torn out, do it right.
    It sounds like you might have to be the "handyman" of the house.
    PVC shouldn't be used for water supply in a house. If anything, you can use CPVC (the beige stuff). If it is plastic it should be pretty easy to rip it out and start over, before you close up the wall. Plastic pipe is pretty easy to do and to avoid leaks, but you must know and use the right techniques.
Similar Threads: leaks shower
Plumbing Forum, Professional & DIY Advice 1970s(?) Kohler/Bradley/Cole Shower Control Leaks Dec 13, 2016
Plumbing Forum, Professional & DIY Advice I have a cvpc shower arm receptor in the wall that has slightly damaged threads and shower arm leaks Nov 9, 2014
Plumbing Forum, Professional & DIY Advice How to test a tub/shower valve body for leaks Nov 3, 2014
Plumbing Forum, Professional & DIY Advice shower faucet still leaks after changing bibb washer and valve seat Jan 26, 2013
Plumbing Forum, Professional & DIY Advice Shower head arm is straight, but leaks Jan 31, 2009
