Im looking for some advice on a plumbing problem. The problem is that there is water leaking from under my pressure tank. I just discovered the problem when my carpet had a big wet spot. Is this something that a do-it-yourselfer can repair, or is it best left for a professional? I have sodered some plumbing in my house before, but Im not sure on this one. I know I have to cut the power, drain the tank, and see what is bad underneath, fix that and soder everything back together. Sounds simple but I have no clue how to drain the tank, if I need to put pressure back into the tank when Im done and probably many other things. Is there someone that can say: Yes you can do it, heres how. OR No, this is best left for a professional. I will post a couple of pictures of the system to better understand what it is I have. Thanks for any help.
BTW the tank is app 11 years old. I have a submersable pump and the line running to the right, with the oarnge shut of valve, goes to the sprinkler system
