Leaking thread on softener
Discussion in 'Water Softener Forum, Questions and Answers' started by Virtualdodo, Aug 14, 2011.
  1. Virtualdodo
    Virtualdodo New Member
    Aug 14, 2011
    Alberta
    Just installed a new whirlpool water softener everything went OK for th most part all my connections worked great, no leaks but the problem happens at the softener, I have 3/4" PEX going to the softener which is a 1" male NPt connection, so to preform this conversion i used a 3/4 x 1" sharkbite this connect my 3/4. PEX to a 1" Copper female threaded connection, put some Teflon on the plastic NPt connection threaded the Copper and I am getting dripping from my IN I have taken it off put on more Teflon put on less tightened it hand tight and wrench tight, nothing works just using Teflon tape on a blue roll if that means anything, my out is leaking to but almost not even noticeable like 1 drip every few min so not sure.
    Any thoughts I am at my wits end here, I am hoping these Copper fittings aren't messed as they cost almost 30 bucks here.
    I wanted a 3/4 PEX to NPt Male then just use a hose to connect which is what whirlpool shows on their site but the local hardware store looked at me like I had a horn growing out of my head.
    Sorry for any grammar and spelling on my phone.
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    With copper, you can tighten it to the 1" threaded connector until you cannot turn it anymore. In other words, thighten the shit out of it.
  4. Virtualdodo
    Aug 14, 2011
    Alberta
    Tried that tightened it right to the bottom of the threads still dripped.
  5. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    I use teflon tape and pipe dope on my connections. May want to try that.
  6. Virtualdodo
    Aug 14, 2011
    Alberta
    So pipe dope first then wrap it in Teflon? I heard not all Teflon is created equally is this true? If so what's the beat stuff? What's the best dope? I hear some only do certain things.
  7. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    Teflon tape first, then pipe dope. Some teflon has a lot of air whipped in to it. Not sure what brand name to buy, I've just always used both and don't get the leaks like you are.
  8. Virtualdodo
    Aug 14, 2011
    Alberta
    I have read lots of stuff on the net to not use pipe dope on plastic as it could break it down especially when water is involved.
  9. Terry
    Aug 17, 2004
    Some pipe dope cans have oil that can soften the plastic.
    Some cans will say if they are okay or not.
  10. Virtualdodo
    Aug 14, 2011
    Alberta
    I called whirlpool and as soon as i said the problem the guy knew the answer he said put Reactorseal #5 on that should fix it he said the copper and plastic will chew through the Teflon tape like butter, Does that sound about right to you guys?
Similar Threads: Leaking thread
Water Softener Forum, Questions and Answers Kinetico experts - water leaking to drain Mar 16, 2017
Water Softener Forum, Questions and Answers Fleck 9000 leaking Aug 16, 2016
Water Softener Forum, Questions and Answers Rainsoft system leaking May 17, 2016
Water Softener Forum, Questions and Answers Fleck 9000 leaking May 11, 2016
Water Softener Forum, Questions and Answers System Leaking Jan 24, 2016
