Leaking shower
Discussion in 'Shower & Bathtub Forum & Blog' started by redmonke255, Dec 29, 2008.
  1. redmonke255
    redmonke255 New Member
    Dec 29, 2008
    Ok, my shower leaks.
    I changed out the seats (actually, I changed the entire system[​IMG] just for the shower).
    When I turn the water back on, it starts to leak. I've tightened the knob all the way off, and it still doesn't work. The seat is tight. The thing that presses against the seat is tight.
    It is hot water that comes out.
    Any suggestions?
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    If you already changed the seat , did you also replace the washer on the cartridge?
  4. redmonke255
    Dec 29, 2008
  5. hj
    faucet
    You installed the wrong seat, or it is not tight, or you have the wrong washer. If the right seat is installed tightly and the correct size washer was used, there is NO way it can leak, unless you damaged the faucet body while doing the repair, and that is seldom the case with a lavatory faucet. Now if it were a tub/shower faucet that would be a real possibility.
  6. redmonke255
    Dec 29, 2008
    It's kinda what I expected. The faucet is old (the house is a good 20 years old), so I suspected a crack.
    We got a plumber to come today and he said it was most likely a hairline crack. He said it would cost around 500-700 USD to fix. :eek:
    So I guess until I get it fixed it would be best to just have a cap on it, right? That way it doesn't drip. :(
  7. hj
    valve
    For that price, I have to assume it is a tub/shower valve, not the sink faucet you used for a picture. If not, then he is ripping you off, big time.
Similar Threads: Leaking shower
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Remodel shower stall kits prone to leaking? Nov 8, 2016
Shower & Bathtub Forum & Blog New home - leaking shower arm inside wall Oct 26, 2016
Shower & Bathtub Forum & Blog Shower drain leaking Aug 13, 2016
Shower & Bathtub Forum & Blog Leaking shower drain: help replacing from top Jul 1, 2016
