Leaking Shower Stall
Discussion in 'Shower & Bathtub Forum & Blog' started by splews, Jul 7, 2005.
  1. splews
    splews New Member
    Jul 7, 2005
    When my shower door frame was installed, the frame was too short so there is a 1/4" gap on one side and a larger one on the inside bottom corner. This came to my attention when I had a leak that needed to be fixed. I removed the old material and recaulked around the door frame but the caulking only lasted a few days before it started getting soft and runny. Obviously they had filled the gap with some other material before caulking. What product can I use to fix this? The drain holes are clear but some water must be sitting in the frame and breaking down the caulking.
  2. jadnashua
    an acrylic caulk may not fully cure or fail if it isn't designed for wet locations. Also, since some caulks can take up to a week or so to fully cure, you may have gotten it wet too soon. The outside would be cured, but the inside is not. I'd consider a full silicon caulk rather than acrylic. My unprofessional opinion. May sure to read the instructions and allow it to cure fully before getting it all wet.
  4. flasugar
    flasugar New Member
    Jul 9, 2005
    work for a large commercial printer
    Florida, USA
    flasugar
    I also have a shower stall that leaks. It is a concrete stall and is leaking through the floor part of the shower. I need to know what to use to seal the floor. The walls are painted and the floor is just plain concrete.
Similar Threads: Leaking Shower
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Remodel shower stall kits prone to leaking? Nov 8, 2016
Shower & Bathtub Forum & Blog New home - leaking shower arm inside wall Oct 26, 2016
Shower & Bathtub Forum & Blog Shower drain leaking Aug 13, 2016
Shower & Bathtub Forum & Blog Leaking shower drain: help replacing from top Jul 1, 2016
